Hi
Once again, thank you for your answers.
If I were living in England in traveling distance from Arceurotrade, I am sure I would drive by and talk with them. If I had to by the Sieg C3 and SX2+ here in Denmark it would probably have had the name Rothwerk and have been sold by people who had not got a clue of what they were trading… ;o)
I bought from Arc because even with postage included money was saved compared to fx. Rothwerk and the SX2 with R8 spindle is not available at all.
I were a bit anxious about the fright. Would the machines be damaged.
Well, on both the lathe and the milling machine the bottom of the plywood case did not withstand the heavy machine during the travel. In both cases the plywood cracked and was splintered but the band around the case did hold it in place and no damage seems to have happened with the machine itself, so i guess that it is not this fright problem that is the course of inaccuracy.
I have already dismantled, cleaned and lubricated the complete X/Y table.
Also I did that on the fine-downfeed (z-axis) mechanism.
The head I have left on its own as everything seems to function ok and I assume that the bearings in the spindle are closed sealed entities and as the SX2 is belt driven there is not much to do inside the milling head.
I did however encounter a problem with the x-travel. At the leftmost end of the table it binded so much even after cleaning and lubricating that I clearly had to do something about it.
I "bit the cake" and used some sanding paper – I did not have any emery cloth – and sanded the dovetail in the left end. In a matter of an hour or so I managed to get it sliding smoothly and the surface were considerably more smooth than the original machined surface from the Sieg factory.
The machine was, as you might already have guessed, bought new. But as the fright is expensive and troublesome the possibility of returning the machine is not an option.
All of this I did consider even before placing my order. I took the chance and did perhaps not exactly win the lottery.
I am not keen to make irreversible changes to anything and certainly not when I am not sure how to do it and if I am making more damage than remedy.
Therefore I think that I do have to stick to shims and probably an aluminium plate that I can machine to a right angle and level workspace on the milling table.
Aside from these troubles I am happy with my purchase.
Had it not been for the Sieg factory I probably would never have fulfilled my dream of a metal lathe neither a milling machine.
Kind regard,
Nyrup
