Mechanically polishing steel castings
Home › Forums › Beginners questions › Mechanically polishing steel castings
  • #76957
    flintlockand steel
      @flintlockandsteel
      Hi
      I frequently need to polish up new steel castings and the supplier recomends and uses a “very very soft” stainless steel brush like really fine wire wool mounted on a grinder.
      Does anyone know where I can get these in the UK?
      PS the supplier couldn’t find the manufacturer’s details so I’m asking here
      #5724
      flintlockand steel
        @flintlockandsteel
        #76958
          If it actually like a wire brush eg actual straight hairs or a stainless wirewool that can be mounted in a die grinder, if the later then it sounds like a “surface conditioning disc” which can be had in different grades to get say various brushed finished on stainless steel etc.
          J&L do various brushes that can be used in a die grinder down to 0.003″ stainless wire probably similar thickness to size 0 wire wool
          J
          Edited By JasonB on 27/10/2011 18:31:32
          Edited By JasonB on 27/10/2011 18:35:22
          #76960
          flintlockand steel
            @flintlockandsteel
            I believe the one my supplier uses is 100-125mm and mounted vertically on a bench grinder the same way a grinding wheel is.
            I think if I knew the precise name or term for this brush I could find it. If I put in soft wire brush etc I get everything but the item I’m looking for
            #76961
              Try looking for wire wheel
              Osborn do a good range
              J
