Marking out blueing or pens?
Home Forums Beginners questions Marking out blueing or pens?
  • #496205
    jon hill 3
      @jonhill3
      I often use a solvent marker pen so my marking out shows up better, however solvent pens don't take well on oily surfaces. Are there pens that will take to any oily surface?
      Also I vaguely remember using a bottle of blueing for the same purpose many moons ago, having made a quick search there are a bewildering variety of different products. Can someone explain the difference in these products… Eg engineers blue in a tin, bluing paste, cold blue etc.
      #10446
      jon hill 3
        @jonhill3
        #496206
        Anonymous
          There are two basic products. Engineers blue in a tin is a sticky paste used to identify high points when scraping. For instance if one wants to scrape a surface flat against a reference (surface plate) the work is smeared with a thin layer of engineers blue. The work is then pushed across the reference surface. The points where the blue has been rubbed away are high points and need to be scraped. Then repeat as required. The watery blue liquid in a bottle is for marking out. It's painted or wiped on where it dries and leaves a thin blue sheen. Scribed line then show up more clearly.
          #496209
          Nigel Graham 2
            @nigelgraham2
            Normal fibre-tip pens won't work on oily surfaces, no, in fact it will harm them.
            Neither will marking-out fluid, which is what you are asking about; but in both cases, clean the surface first with a suitable solvent such as meths, which will also remove the ink afterwards.
            When marking out rough or dark materials like hot-rolled steel, I sometimes clean the surface, spray it with a couple of coats of grey primer and mark out with a sharp pencil.
            #496210
            IanT
              @iant
              I use both Jon
              For quick jobs, then a black 'Sharpie' works well on both steel and brass. It's convenient and quick – so a quick dab on a turned part to mark (say) the length of cut – is very handy. It does rub off fairly easily though, so it's not quite as "permanent" as the name suggests – at least on metal.
              For larger/more involved work I still use Marking Out Blue – my small bottle of which I purchased from GLR donkeys years ago. You just paint it on with a small paint brush (I use children's ones). After use just let them dry out – they will soften very quickly when re-dipped in the blue. This blue stays on a lot better than Sharpies but can still get worn/rubbed away as the work progresses. So quite often I will place a few punch marks on marked lines for instance to keep the important reference points even if the marking wears off.
              Many here will just drill/cut straight from DRO readings these days of course but I still like to see parts marked out.
              IanT
              #496214
              Mike Poole
                @mikepoole82104
                Dykem layout blue is an excellent product for marking out, scribed lines are clear and crisp. Permanent markers are very convenient but the durability is not very good if the item is handled very much. Dykem takes handling much better. Engineers blue is for checking fits or against a reference surface.
                #496215
                Mike Poole
                  @mikepoole82104
                  If you mark out you get a chance to think about whether it’s right before you cut metal. If you are confident then a DRO and diving straight in is a quick way to work but a mistake can be more difficult to rectify than rescribing a line.
                  #496225
                  Ian Johnson 1
                    @ianjohnson1
                    Try the new Sharpie 'Pro' felt tip marker pen, it writes on oily or wet surfaces. Bought one today from the local supermarket £3
                    IanJ
                    #496232
                    Tony Pratt 1
                      @tonypratt1
                      Clean the oil off
                      #496233
                      Thor 🇳🇴
                        @thor
                        I use both marker pens and layout blue. For laying out just a few lines or points the marker pens are very convenient, if laying out lines that will be used later on during several machining processes I use the more permanent layout blue.
                        Thor
                        #496237
                          Please forgive the slight digression, but I must mention a recent ‘find’
                          I was reading a piece about making steel clock-hands, in which it was casually mentioned that the material was ‘blued’ prior to marking-out with a very fine scriber.
                          Nothing unexpected in that“ you might say : but the author was talking about blueing with heat [as one would normally do when finishing the hand]
                          This seems an exceptionally good idea, if the workpiece is suitable.
                          Bo’sun
                            @bosun58570
                            Hi Jon,
                            Like the above, I use both. Permanent marker for small areas, and layout ink/fluid for larger areas. Buy a decent layout fluid such as dykem, I've found cheaper ones take ages to dry and tend to flake off when scribing into them.
                            #496258
                              Scraping is the classic application of Engineering Blue paste but it's good for identifying any area of poor fit, like checking tapers, or confirming a gib is pressing evenly. A small tin lasts forever.
                              It's possible to make a 3rd rate layout blue substitute from paste by dissolving it in Meths. Inferior to real Layout fluid and felt-tip, but handy in a pinch.
                              Before layout blue, steel was dipped in slightly acidified Copper Sulphate solution, which deposits a thin layer of Copper on the surface. Works quite well, but fussy. Dipping tanks take up space and the chemicals are a mild hazard. Mostly I use felt tips. Decent brands work better than pound shop cheapies, but it's not critical
                              All layout fluids need a clean surface – remove oil first.
                              Edited By SillyOldDuffer on 17/09/2020 09:56:08
                              #496262
                              Steve Withnell
                                @stevewithnell34426
                                I started off using acidified copper sulphate solution, mainly because I was learning from books that came out of the Ark's library. Then got converted to a big fat black Sharpie and never needed anything else for marking out.
                                #496265
                                jon hill 3
                                  @jonhill3
                                  I was interested to here about oil resistant makers eg sharpie pro, I just discovered staney make one to. Has anyone used these pens and do they live up to the hype?
                                  #496272
                                  Vic
                                    @vic
                                    I switched to using jumbo permanent markers years ago, they work very well. I’ve not done it but I believe some of them can be refilled to keep costs down.
                                    #496276
                                    mechman48
                                      @mechman48
                                      I don't have that many projects on the go, mainly small engines, & then only one at a time; I prefer to use Jumbo markers for any flat surfaces & chisel pointed sharpies on others so find them quite effective.
                                      During my apprenticeship we were taught to use Dyekem layout fluid as the preferred method but we also used copper sulphate mix, whitewash mix ( white lead ) on cast srfaces, now long since banned. I belive Copper Sulphate is still obtainable from some gardening centres if you want to try that out. To date; jumbo & Sharpies do fine for me.
                                      George.
                                      #496286
                                      Circlip
                                        @circlip
                                        Tinned "Engineers Blue" – a little goes – – – – – all over the b****y workshop, as many will attest.
                                        Regards Ian.
                                        #496297
                                        Robert Atkinson 2
                                          @robertatkinson2
                                          Jon,
                                          You mentioned "cold blue". This is totally different. it is used to produce the protective bluing of steel used on guns etc. While you could mark out through tthis I won't help with your problem because it won't work on oily material. And of course it only works on ferrous metals.
                                          Robert G8RPI
                                          Edited By Robert Atkinson 2 on 17/09/2020 12:11:34
                                          #496306
                                          Vic
                                            @vic
                                            I’ve got both Blue and Red markers but not sure I’ve used the red one. It seems the British prefer blue whilst the Americans prefer red. Or am I mistaken?
                                            #496314
                                            Howard Lewis
                                              @howardlewis46836
                                              Prussian blue (Mine is Micrometer Brand &nbsp is DIFFICULT to remove from fingers, but ideal for scraping surfaces.
                                              For marking out, Spirit blue is the one to use. Again hard to remove from fingers!
                                              A Sharpie or a blue felt tip (Chisel point) can be used for marking out, but, is not as durable, in my experience, as spirit blue.
                                              HTH
                                              #496330
                                              Ian Johnson 1
                                                @ianjohnson1
                                                During my apprenticeship we used blue marking out for bright metal like mild steel or aluminium, and white marking out for dark metal like cast iron.
                                                Getting a contrast when marking out makes things a lot easier to see.
                                                IanJ
