Machine specs aluminum plates
Home › Forums › General Questions › Machine specs aluminum plates
  • #441020
    Massimo Dalmonte
      @massimodalmonte45801
      Good afternoon ,
      I always wondered how the black and "white" aluminum plates found on various appliances (specs on electric motors, speed charts on lathes, etc) are manufactured.
      I think it involves a silkscreening process, but I don't know how the black part is obtained (it' doesn't look to be a paint, more some black oxide, as it is tightly adhering to the underlying metal, with no discernable thickness).
      If somebody knows more about the process, I would be happy to learn something new.
      Massimo
      Edited By Massimo Dalmonte on 10/12/2019 11:41:42
      #27003
      Massimo Dalmonte
        #441026
        Brian G
          @briang
          Take a look at http://www.gsmgraphicarts.com/ Massimo, the manufacturers appear to offer several different methods.
          Brian G
          Edit:  I just learnt (nearly 40 years too late) that the instrument manufacturer I used to work for had the wrong description on its drawings, and that the round head rivets that secure nameplates should be called drive screws, not drive rivets.
          Edited By Brian G on 10/12/2019 12:58:14
          #441030
          Martin Kyte
            @martinkyte99762
            It can be done like this.
            Laser Engraving
            skip to 3/4 of the way through if you dont want the layout process.
            regards Martin
            #441046
            old mart
              @oldmart
              The coloured aluminium plates are produced by first anodising the plates. This is a protective surface which is porous, a bit like an open honeycomb on a microscopic scale. Selected parts are masked off, usually by photographic resist or silk screening. The part is then put in a bath of hot dye which soaks into the bare areas. The resist/silk screen ink is washed off and another part is left bare for more dye of a different colour. This can be done several times. An example is used on the speed control levers on older Colchester lathes.
              Massimo Dalmonte
                Thanks everybody,
                so the plates I was referring to are dyed anodized aluminum (always thought of color anodizing as covering the whole object and not only some parts of it…); it almost seem I could replicate this at home, using the same photoresist film used for pcb, though there is surely a learning curve to get decent results.
                Massimo
                #441083
                old mart
                  @oldmart
                  Here's a link: **LINK**
                  #441109
                    Posted by Massimo Dalmonte on 10/12/2019 14:59:17:
                    Thanks everybody,
                    Massimo
                    It can be done, but my own efforts were 'inconclusive'.
