Machine Oils – Old Spec (Current Equivalent)
Home › Forums › Beginners questions › Machine Oils – Old Spec (Current Equivalent)
  • #654421
    Antony Harding
      @antonyharding74298
      Hi All,
      Can you kinldy help on directing me on whats Oil / Grease I can buy what are the equivalent to the old sepc oils / greases as noted in the manuals (Beaver Mill & Smart & Brown Lathe)
      MILLER
      – Shell Vitrea 33
      – Shell Macoma 75
      – Alvania 2
      LATHE
      – Mobil DTE Light Oil
      – Castrol XL
      On both machines there are grease nipples, is there a grease gun that you can buy whcih is slef filling? i.e that does't use the grease catridge tubes?
      #11542
      Antony Harding
        @antonyharding74298
        #654422
          Posted by Antony Harding on 30/07/2023 15:21:01:
          Wanner One-Hand Grease Gun
          … I’ve had mine for decades
          Anonymous
            Just because it looks like a grease nipple doesn't mean it is for grease – RTM. smile
            #654428
            Dave Halford
              @davehalford22513
              Castrol XL was multigrade engine oil from 1900 and frozen to death still available on ebay at £15 per L
              PS you can refill cartridge grease guns
              Edited By Dave Halford on 30/07/2023 16:24:29
              #654430
                See here for most of what I know about Vitrea: **LINK**
                https://www.model-engineer.co.uk/forums/postings.asp?th=171223&p=2
                Howard Lewis
                  @howardlewis46836
                  The machine may have grease nipples, but in some cases, putting grease through them can be BAD news. The grease will solidify, so that the oilway is blocked and the bearing gets no lubrication.
                  It may well be that the correct lubricant for that particular point should be oil.
                  If you need an oil gun, I can recommend a Rielang, may seem costly, but does not leak and works at almost any angle.
                  HTH
                  #654598
                  Antony Harding
                    @antonyharding74298
                    Hi all, many thanks for the help and info…. its got me on the right track.
