M24 x 2 arbour
M24 x 2 arbour
Home › Forums › General Questions › M24 x 2 arbour
  • #26978
    carl carley
      @carlcarley97387
      can you get one with a MT2?
      #439124
      carl carley
        @carlcarley97387
        ive a large boring head that has an m24 x 2mm arbour thread, can you get this on a MT2 arbour or is it just to small for such a large thread or does m24 x 2 have a 'name'
        regards
        carl
        #439125
        Emgee
          @emgee
          Carl
          Get yourself a blank end MT2 arbor and thread it in the lathe.
          Emgee
          #439128
          carl carley
            @carlcarley97387
            I did think about that but my spindle is mt4 and a reducer would not be so accurate
            #439135
            Emgee
              @emgee
              Carl, find an old used MT4 drill, 1" or bigger, cut it down and use that for the arbor, probably a good idea to thread for a drawbar for security in use.
              Emgee
              #439152
              Hopper
                @hopper
                Posted by carl carley on 27/11/2019 22:09:05:
                Should be accurate enough for this job.
                It does not matter even if the boring head does run a tad off true.The cutting tip will gtravel a perfect circle regardless.
                Chronos and others sell a MT2 boring head arbor with a 1.5" thread that could be turned down to suit.
                Most arbors seem to have an imperial thread. (Don't get it confused with the oft quoted drawbar thread of 10 or 12mm or half inch etc). Are you sure yours is 24mm and not 1" ?
                #439172
                DC31k
                  @dc31k
                  Posted by Emgee on 27/11/2019 22:00:28:
                  All the boring head arbors I have seen are flanged after the thread, to stop the head screwing itself into the spindle. Finding a MT2 blank arbor of big enough diameter to accommodate this may prove challenging.
                  #439173
                    Posted by DC31k on 28/11/2019 08:38:51:
                    At the risk of sounding like a scratched record:
                    Loctite 638 or similar … Loctite 638 or similar … Loctite 638 or similar
                    carl carley
                      @carlcarley97387
                      i have pondered on softening the arbour it came with and
                      a) turning a MT2
                      b) cut off existing taper and drill/tap for a more readily available MT2 arbour
                      the one from chronos looks promising tho
                      cheers
                      carl
                      #439180
                      KWIL
                        @kwil
                        Allendale Group, in stock for M20 but not M24
                        Edited By KWIL on 28/11/2019 09:07:04
                        #439185
                        Hopper
                          @hopper
                          Depends how hard the original is too. You might be able to turn it down using carbide tooling?
                          Some of the cheapies may not even be hardened at all.
