Interesting new UNIMAT (is it 6?)
Home Forums Beginners questions Interesting new UNIMAT (is it 6?)
  • #95912
    Ady1
      @ady1
      On fleabay, but it's the interchangability of composite sections which makes it interesting
      Almost like a Transformers Toy
      Remove the X at the beginning of the http://www.Xebay link to view
      unimat
      #6276
      Ady1
        @ady1
        #95915
        David Littlewood
          @davidlittlewood51847
          Link didn't work for me.
          David
          #95916
          John Stevenson 1
            @johnstevenson1
            For some reason he put an X infront of Ebay ?
            Alistair Grant 3
              @alistairgrant3
              David, Just go to ebay site and search for 330767741825. This is the item number
              #95918
                Here is Cool Tool website
                and there is a promotional video on You Tube, dated 04-Dec-2007
                [not for me, thanks]
                Ady1
                  @ady1
                  fleabay links are verboten in here
                  #95922
                  Gone Away
                    @goneaway
                    Posted by Ady1 on 08/08/2012 01:02:32:
                    Are they? When did that happen? …. seems to me there have been plenty in the past
                    #95924
                    Springbok
                      @springbok
                      Ve haf vays of makeing you talk so you had better explain vy das ist verbotten!!
                      Boblaugh
                      #95927
                        One interesting point … mentioned in the text under that You Tube Video
                        The availability of [very] long beds and cross-slides. enlightened
                        That's a significant advantage of using extrusions … I wonder if they are available individually ?
                        ______________________________________________
                        With a nod to Michael Williams' comments on the Metalmaster threadobviously there would be terrific problems with alignment at those distances … but it would be very useful raw material.
                        Edited By Michael Gilligan on 08/08/2012 07:43:16
                        #95928
                          O.K. "Cool Tool" suddenly gets very interesting.
                          Would this install and run on a Raspberry Pi ???
                          First thoughts are here
                          GPIO looks the way to go
                          Edited By Michael Gilligan on 08/08/2012 08:15:40
                          #95930
                          David Clark 13
                            @davidclark13
                            Who banned Fleabay links then?
                            We might delete them if somone consistently posted links to their own auctions otherwise we leave them alone.
                            They are obsolete in a few weeks anyway so not a good idea.
                            regards David
                            Edited By David Clark 1 on 08/08/2012 10:13:14
                            #95932
                            DerryUK
                              @derryuk
                              <Would this install and run on a Raspberry Pi ???>
                              There is a caveat in LinuxCNC requirements that video and system memory should be separate ie not shared in system memory.
                              The way things are going with RasPi though someone will crack it.
                              #95935
                                Thanks Derry,
                                I will sit back and wait for the Geeks to do something amazing.
                                Peter G. Shaw
                                  @peterg-shaw75338
                                  This is the metal version of the original Unimat 1 which is a very low power machine using plastic & aluminium.
                                  Peter G. Shaw
                                  #95954
                                  Kevin Bennett
                                    @kevinbennett25223
                                    hi all you can do anything with this type of aluminium extrusion if you want to be creative you can get all types of aluminium extrusion from Flex link i am having a go at using it for a cutter grinder using the 40 x 40 mm section.
                                    i am lucky as i have a contact at my old work place so i can get hold of small off cuts
                                    TY Kevin
