I C valve grinding paste
Home › Forums › I/C Engines › I C valve grinding paste
  • #634382
    Dougie Swan
      @dougieswan43463
      Hi
      Can anyone suggest the best size of grit for lapping in ic engine valves
      I'm thinking of getting some of the finer diamond grades
      Any advice
      Thanks
      Dougie
      #2647
      Dougie Swan
        @dougieswan43463
        #634383
          I usually do mine with 600grit silicon carbide powder mixed with oil to form a paste. 100grams off e-bay will last a lifetime
          #634384
          bernard towers
            @bernardtowers37738
            Carborundum is the paste to use as it does not bed into the valves or seats, I think I would be worried that diamond would do the opposite as its virtually indestructable.
            #634391
            old mart
              @oldmart
              I went into Halfords ten years ago and asked for a tin of valve grinding paste, to my astonishment, they had never heard of it. I went to a small car bits shop and the guy said that there was a choice of two different makes in stock. I would choose the finer grade in the double ended tin. I would avoid diamond  abrasive for valves.
              Edited By old mart on 20/02/2023 21:09:39
              #634396
              noel shelley
                @noelshelley55608
                I would use the double ended tin, it will last for years, Holts and chemico both do it, I'd go for chemico, If you have a branch of MPD near they will have it. Noel.
                #634425
                  I expect Dougie want's it for model engine valves and even the fine half of a tin of automotive grinding paste is way to coarse for model use.
                  #634437
                  Hopper
                    @hopper
                    Metal polishes such as Brasso and Solvol Autosol aluminium polish are a good fine abrasive for smaller jobs. Brasso is a bit too fine sometimes but the Autosol works well. As does Mothers Aluminium Polish. Never tried it on small model IC valves though.
                    #634454
                    Dougie Swan
                      @dougieswan43463
                      Thanks for all the replies
                      I have used the fine end of car valve grinding paste and as Jason says it's a bit rough
                      I will try to get my hands on some finer carbide
                      Thanks
                      Dougie
                      #634502
                      Rick Hann
                        @rickhann79631
                        Timesaver Sampler Pack. 8 different grades. 4 each for ferrous metals and 4 each non-ferrous metals. Non embeding! I have used it for more than 25 years. Rick
                        #634506
                        Dougie Swan
                          @dougieswan43463
                          Thanks
                          Where is the sampler pack available from
                          Dougie
                          #634508
                          Ramon Wilson
                            @ramonwilson3
                            Dougie – I have plenty of Silicon Carbide (Carborundum) powder in 280 (too coarse for piston/liner lapping actually) 320, 600 and 1000 grits.
                            Send me a PM if you want some.
                            'TimeSaver' is great but far too expensive when only small quantities are required.
                            Diamond is a definite no no if the surfaces are not hardened. It will embed itself into the material and no amount of solvent cleaning will release it all. You need a good ultra sonic cleaner to do the job properly.
                            Silicon Carbide is ideal – does a good job and is easily removed with a solvent such as cellulose thinner. I haven't done any valves but I have done the odd piston and liner.
                            I am disposing of some of my workshop – Silicon powder is no longer required nor some genuine Kasenite case hardening powder – if anyone else wants some then PM me.
                            Best Tug
                            Edited By Ramon Wilson on 21/02/2023 18:38:32
                            #634510
                              Heritage steam do the sets, but at about £100 a pop that's a lot of valves you could grind in compared to £3-4 for 100grams of 600grit off e-bay
                              You could buy just a jar of very fine but it is still coarser than 600g
                              #634686
                              Rick Hann
                                @rickhann79631
                                Posted by Dougie Swan on 21/02/2023 17:59:27:
                                Thanks
                                Dougie
                                I bought mine years ago from McMaster-Carr. There was a discussion a while back and if I remember correctly, it was hard to find in Europe and expensive. Probably not worth it for one or two jobs. I have built numerous engines over the years and I would not be without it. Still have 50% of it left. A Google search should turn something up if you are still interested. Rick
                              Home › Forums › I/C Engines › Topics
