I now know my lathe is missing several change gears for screw cutting for standard and metric threads it comes with 30, 45, 55, 60, 65, 70,75,120 and 127 I only have 30.60,65 and 120 the 60 has one tooth missing so I need to replace that one as well they are 20° pressure angle gear.
The 6 gears I need are 45,55,60, 70,75, 127
The gear measures the best i can with a vernier 16mm (0.63) thick the hole is 19.04mm (0.7500) and the keyway is 6.3mm(0.2490) widw and 2.82mm (0.1110).
