Help With Choosing Thread
Home › Forums › Beginners questions › Help With Choosing Thread
  • #109893
    john dakin
      @johndakin59277
      I plan to make a stub arbor for 1" gear milling cutters, I have no idea what size thread i need to put on the end of the arbor for the retaining nut, is there some sort of formula for working this out????
      #6539
      john dakin
        @johndakin59277
        #109895
        Gray62
          @gray62
          Just had a quick look at the arbors I have and both the stub and horizontal arbors have a 7/8" x 20 tpi thread.
          Hope this helps.
          regards
          CB
          #109919
          MICHAEL WILLIAMS
            @michaelwilliams41215
            7 / 8 inch by 20 tpi certainly ok . Really it doesn't matter that much but there are just a few considerations :
            Nut and associated washer need to run up to the cutter nice and square so as to get an even clamping load – this really means arbour and nut need to be be screwcut if possible – so choose a nice simple thread pitch .
            Not usually a problem if you are running cutters the normal way round but consider provision for a locknut if ever needed .
            Michael Williams .
            PS : In happier times all sorts of machine shop sundries could just be bought – including standard cutter arbour nuts and washers . Try WDS or similar – you might get lucky .
