Hello from Hampshire
  • #361731
    James Brighton
      @jamesbrighton15434
      Hello all,
      My name is James and I have taken up model engineering in the last two years, fitting it in as I can around kids and work.
      My main interest is in steam locos, I presently have a 5 inch gauge A4 which requires a fair bit if TLC but suits my needs.
      I also work on and off on my fathers locos.
      Presently in the process of acquiring a few small bits of workshop equipment so that I can work from home on my project.
      Look forward to chatting to others and getting a few tips and pointers from here.
      James
      #40349
      James Brighton
        @jamesbrighton15434
        #361742
        David George 1
          @davidgeorge1
          Hi James welcome to the forum, lots of like minded people here, if you need help just ask. What machinery do you have.
          David
          #361751
          shaun meakin
            @shaunmeakin78815
            Hi James, the Thornbury Model Engineering Exhibition is 17/18/19th August. Not a million miles from Hampshire and a really well run and popular show full of like minded model engineers. I'm sure you would find it very enjoyable, stuff for the kids to see too!
            Shaun.
            #361761
            KWIL
              @kwil
              James, Welcome, please complete a Public Profile, even if you only say "xxxx, Hampshire". Helps if you need specific help such as "where's the nearest Club" etc.
              #362749
              James Brighton
                @jamesbrighton15434
                Hi all,
                I’m from Andover to be exact.
                Presently my machinery is not a lot as most of it is tools, welding gear, compressors and the such like.
                I have access to lathes, drills and a mill which I use on and off.
                Looking for a lathe presently which a lot of members have given me very helpful advice on.
                A lot of work I do (for enjoyment) is fabrication and after inheriting a loco which needs some TLC I’d like to do it myself and improve my somewhat agricultural machining skill set.
                #362750
                Martin King 2
                  @martinking2
                  James, You have a PM, look for the flashing INBOX item in menu bar!
                  Martin
