Glass cutting !
Glass cutting !
Home › Forums › The Tea Room › Glass cutting !
Viewing 23 posts - 1 through 23 (of 23 total)
  • #344155
    J Hancock
      @jhancock95746
      After 24years the 'double glazing' in my house is 'blooming' between the glass..
      As usual the builders fitted the cheapest ,with only a 10mm gap , as a thermal insulator it is next to useless. No problem with that.
      What I would like to do is remove one pane ( i.e make it single glazed ) without
      interfering with the installation. That is, in situ.
      Now, how best to ' break the glass' ?
      On the inside ?
      On the outside ?
      Use a single point diamond tool ( my grinding wheel dresser ) ?
      Conventional glass cutter ?
      What to use to dress any ragged edges back ? I have a die grinder.
      Panes are not big , approx 20"x 16".
      Ideas welcome.
      #35128
      J Hancock
        @jhancock95746
        #344162
        Clive Hartland
          @clivehartland94829
          The method of holding the glass in the frame governs how you do it, in between the glass is a dessicant strip so this must remain inside the system so you will have to take out the rear pane of glass. Old glass is hard to cut so you need a new glass cutter. use a lubricant like soapy water and run around the edge of the frame and then maybe across each corner, tap in the middle and you 'may' get a clean break.. Nothing is guaranteed, you may get hell of a mess or it will go like magic. How to clean up the edges is another story!
          #344163
          Billy Bean
            @billybean67480
            We had leaded lights replaced with clear panes a while back.
            The glazing firm had wide rolls Sellotape material they stuck to both sides of the glass.
            They then removed beads and put a flat blade in to release pane
            Often the pane broke but the sellotape stopped any glass going anywhere.
            BB
            #344164
            blowlamp
              @blowlamp
              Mine have blown too (20mm units), but I'm going to try this method.
              Martin.
              Edited By blowlamp on 03/03/2018 11:39:35
              #344181
                Replacement double glazing panels are surprisingly affordable. You may be doing yourself a favour by looking up the cost and comparing to the cost/faff of converting to a single pane.
                #344184
                Barnaby Wilde
                  @barnabywilde70941
                  Last time I handled a double glazed panel it shattered into diamonds when a corner touched the floor !
                  Every area should now be well covered by specialist double glazing repair men, get a man in
                  #344186
                  blowlamp
                    @blowlamp
                    Posted by Neil Wyatt on 03/03/2018 12:25:25:
                    I've got about 26 units that need attention, so I'm going to try the starter kit for £210 which does 12 units.
                    If all is OK, then I'm doing the rest the same way, as (predominantly south facing) new units are bound to fail eventually anyway.
                    Martin.
                    #344191
                      What height is the panel situated at and what size, chances are it may be toughened and you won't cut that just end up with thousands of bits all over the carpet.
                      10mm gap was considered good 24yrs ago and 6 was more common.
                      Edited By JasonB on 03/03/2018 13:21:33
                      #344198
                      pgk pgk
                        @pgkpgk17461
                        I replaced several double glazed units in a conservatory that i'd built many years before.. again suprised by how relatively little they cost to have made up by a local double glazing place – ready to pick up in a couple of days.
                        Also i dont know if they still do them but wicks (uk) used to stock timber frames and double glazed glass in standard sizes and one could just buy the glass if they had a size to fit.
                        Lastly if the units will come out easily then any drilling might be possible from the side between panes for those that want to play at fixing them. That mght avoid some mess.
                        pgk
                        #344202
                          Posted by J Hancock on 03/03/2018 11:25:02:
                          On the inside ?
                          On the outside ?
                          Ideas welcome.
                          I wouldn't do it; depending on the exact construction it could get very difficult and messy. Even done well the results will be inferior to doing the job properly. However, if you fancy a go why not?
                          Removing the outer pane will expose the inside of the frame to the weather: expect corrosion and unsightly puddling. I'd go for the inner panes.
                          The glass will probably be tempered. I suggest the best way to remove it is to shatter it with an automatic centre-punch. The bits will fly everywhere, so use sheeting to contain it.
                          Early and upstairs fittings may be ordinary glass. All my attempts to cut ordinary glazing in situ with a cutter have ended in tears. Perhaps I don't have the knack! Ordinary glass is nasty in that it breaks into razor sharp shards and grinding the edges is time consuming and liable to break the glass again. You can't leave razor edges on the inside of your windows.
                          I don't know how difficult it will be to tidy up where the glass meets the panel side. My double glazing is a sealed unit and the edges may glued in solid.
                          Perhaps the best thing is to investigate the cost of replacement panels first. If that's off-putting experiment on a single panel to see how easy it is (or not!) to remove a single pane. One thing to watch. If replacements are priced like windows, it will be much cheaper to have the whole house done at the same time rather than to do panes piecemeal.
                          blowlamp
                            @blowlamp
                            #344221
                            Sandgrounder
                              @sandgrounder
                              As an example of cost I've just had a replacement double glazed unit fitted with toughened glass, size was 900mm x 800mm, total cost of unit plus fitting £80.
                              Edited By Sandgrounder on 03/03/2018 15:31:06
                              #344223
                              Gordon W
                                @gordonw
                                As said, buy new double glazed panels. Most will be standard sizes, if not ask round some local firms and get prices. The most I paid for about a metre square was £40 2 years ago. When you measure up allow about 6mm less ie. 3mm all round and state " glass size ". Get some good clear silicon mastic and away you go.
                                #344261
                                J Hancock
                                  @jhancock95746
                                  Many thanks for those ideas and suggestions.
                                  I should have mentioned that I still have the original wooden window frames.
                                  There is a humorous side to this.
                                  Since I am the only house left on the development that hasn't had all the frames replaced by plastic I always get
                                  the undivided attention of the various 'reps' trying to sell plastic/double glazing. Pain,pain.
                                  So far, they have believed my story that my house is covered by Heritage status and cannot be changed.
                                  #344278
                                  Martin King 2
                                    @martinking2
                                    An important thing to remember when fitting DG panels if you are using a sealant is to make sure you get a neutral PH, specifically one for glazing. If it smells of acetic acid (vinegar) the units will soon have condensation inside them.
                                    DAMHIKT!
                                    Martin
                                    #344284
                                    Speedy Builder5
                                      @speedybuilder5
                                      Be brave, take the DG panel out and saw thro the mastic / aluminium spacer with a circular saw – then you will have two panes of glass for each window !!
                                      BobH Ps, wear protective gear.
                                      #344290
                                      Muzzer
                                        @muzzer
                                        JH – the usual method is to say you are renting. Short discussion….
                                        #344304
                                        Sandgrounder
                                          @sandgrounder
                                          Posted by J Hancock on 03/03/2018 19:52:15:
                                          I had exactly the opposite experience, I drew up a list with all the window sizes and took it to a local firm, he gave me a quote of about £2500 and I asked him to come and have a look at the job to discuss details, he refused and said he'd only look at it if gave him the order, I went somewhere else.
                                          J Hancock
                                            @jhancock95746
                                            Speedy Builder,
                                            Simplest, cleanest option for me I think.
                                            Thanks for that, Spring /Summer job sorted.
                                            #344354
                                            Chris Gunn
                                              @chrisgunn36534
                                              I just paid £35 for a unit 900 x 550, and fitted it in 2 or 3 hours, the worst bit is cleaning out the old putty. This was bought from a local small glazer, I found the companies that advertise on the web much more expensive.
                                              Chris Gunn
                                              #344355
                                              blowlamp
                                                @blowlamp
                                                Posted by J Hancock on 04/03/2018 08:25:55:
                                                Speedy Builder,
                                                How will you bring the unit back to the correct thickness?
                                                #344387
                                                Muzzer
                                                  @muzzer
                                                  If I bought a house with single glazing it would be on the expectation of having to replace them all with double glazed units – this would come off the price. I'd also wonder what else the previous owner had turned his fists of ham to. Removing them all, bodging them as proposed and refitting them will cause more damage and loss of value than if you did it properly. Find a local glazing panel manufacturer and get a proper quote rather than run the gauntlet of the salesmen – I think you'd be surprised how affordable it would be. Conversely I'd suggest you couldn't afford not to.
                                                  Murray
