Flywheel help please
Home › Forums › General Questions › Flywheel help please
  • #341323
    Linda Thompson
      @lindathompson12321
      Hi, can anyone tell me where I can get a 5 spoked alloy flywheel with a diameter of between 10in & 11.5in
      #25806
      Linda Thompson
        @lindathompson12321
        #341335
        Linda Thompson
          @lindathompson12321
          I’ve been recommended to ask Myfordboy. Anyone know how I can get in touch with him ?
          #341336
          Billy Bean
            @billybean67480
            Try a google search – website and contact details are all there.
            #341337
              I deleted my suggestion as his is 6 spoke not 5 but if that will do you his contact details are on his blog
              I think you are going to have a hard time finding what you are after. 5 spoke flywheels are not that common so that will narrow things down and the other factor is weight as aluminium ones don't work as well as ones made from something heavier
              Can I ask what it is for?
              Edited By JasonB on 13/02/2018 18:37:11
              #341338
              Bob Stevenson
                @bobstevenson13909
                You can contact 'myfordboy' by email….if I recall you can find it at the front of his youtube channel.
                You can also tackle the people who have castings for model engineers such as 'College Engineering' as they may either be able to supply a casting or make you one……
                #341343
                Linda Thompson
                  @lindathompson12321
                  Thank you, I have emailed him
                  #341364
                  Brian H
                    @brianh50089
                    Another option is to have the five spoke flywheel CNC'd.
                    #341373
                    John Baron
                      @johnbaron31275
                      Hi Linda,
                      Have a look around a scrapyard at washing machine pulleys. Most have five spokes and are made of alloy, though some are plastic. I have several, one of the plastic ones I made into a lathe handle.
                      #344325
                        Well with the recent thread on completing posts I thought I would post this as we all like a happy ending.
                        Although I had removed my suggestion of contacting Myfordboy due to his flywheel being 6 spoke and not 5 spoke he was able to print a pattern for the required pulley and cast one for Linda. Video of it here from screen to finished item.
                        J
                        PS Just waiting for my commission nowwink 2
                        #344333
                        Billy Bean
                          @billybean67480
                          Daft question time as the first time I have seen a casting video.
                          Why is the flywheel wooden bit in two parts as opposed to being in one piece ?
                          A very interesting video and the casting looks superb – a commentary on what and why he was doing would have helped me understand it more.
                          Thanks.
                          BB
                          #344339
                          not done it yet
                            @notdoneityet
                            If the one piece pattern was embedded in sand, one could not remove it. If making a 3-D printed pattern and burning it out before casting, one could use a single piece pattern.
                            #344341
                            Anonymous
                              Posted by Billy Bean on 04/03/2018 10:43:40:
                              It's a slightly odd way of doing it. Of course you need to mould the drag and cope separately. Often the halves of the pattern are mounted on each side of a board. Then locating pins are used on the drag to pick up holes in the moulding board and cope so everything should be aligned automatically.
                              #344343
                              Cornish Jack
                                @cornishjack
                                Absolutely fascinating, mind-boggling expertise!! thumbs upthumbs upthumbs up
                                Obviously, he's done it once or twice before but how long did it take, overall, and how would you cost up that manufacturing sequence?
                                rgds
                                Bill
                                Edited By Cornish Jack on 04/03/2018 12:02:22
                                #344347
                                  Another reason for printing a 2-part pattern is that it avoids having an 'underside' with a less than perfect surface finish.
                                  Stewart Hart
                                    @stewarthart90345
                                    Posted by Linda Thompson on 13/02/2018 17:11:48:
                                    You can try getting one laser cut there's plenty of jobbing shops with laser cutters around all you need to do is send them a drawing and ask for a quote
                                    This is one I had done.
                                    And the completed fly wheel
                                    Stew
                                    #344360
                                      It is possible to do a sand casting with a one piece pattern, lay the pattern in teh bottom of the drag box, pack sand around it in the usual way but when you turn it up the other way you need to carfully carve away the sand down to the half way point. You then dust with talc and ram up the cope as you would with a 2 piece pattern. First casting I ever did was done that way using a Mamod flywheel as the pattern. Gives a perfect finish to both sides.
                                      Having the two halves on match boards is the ideal way for production or small batch work buy one offs or short runs it is as quick to do them without a board which is what I have done for the last few I have had cast. Also means the foundry can often squeeze them into the corner of a larger box to keep costs down. Just use pegs and sockets to line up the two halves. You can just about see the pegs/sockets on these.
                                      Edited By JasonB on 04/03/2018 13:14:08
                                      Edited By JasonB on 04/03/2018 13:21:05
                                      #344749
                                      Linda Thompson
                                        @lindathompson12321
                                        My flywheel arrived today made by myfordboy and it is perfect. Cant recommend him highly enough.
                                        #344754
                                        Brian H
                                          @brianh50089
                                          Posted by Linda Thompson on 06/03/2018 20:11:12:
                                          So pleased that someone on here was able and willing to help.
