Displacement lubricator and safety valves
Home › Forums › Beginners questions › Displacement lubricator and safety valves
  • #828437
    Brian John
      @brianjohn93961
      1. I have been absent from the hobby for a few years and I noticed that the displacement lubricators that I purchased from PM Research in the US have lost their ”rubber” rings on the valve/control wheel. They have rotted away. What can I use to replace them ?
      2. In the past I used Mamod safety valves on my home-made boilers (tiddlers – very low pressure) but I have found that Mamod have gone broke. Is anybody making replacement safety valves to fit all the Mamod machines still out there ?
      #828443
        Hello stranger
        I think PMR just use small O rings stretched onto the brass central wheel so you should be able to measure the cross section and work out the diameter then order online from a bearing or seal supplier of Australian ebay.
        #828447
        Weary
          @weary
          Mamod safety valves available on ebay and loadsa other places.
          There is a Mamod Owners Group on facebook if that is your thing & they will give you plenty of leads.
          Phil
          #828448
          Brian John
            @brianjohn93961
            Nitrile rubber – oil resistant ? Or is there something else more suitable ?
            #828449
              Go for Viton it resists oil better. Sometimes also sold under the name FKM
              #828502
              Nigel Graham 2
                @nigelgraham2
                1) The stockists of seals etc often have charts showing O-ring grades suitability by application.
                2) If necessary, carefully and non-destructively analyse an existing Mamod valve from one your models, and copy that.
                #828507
                Brian John
                  @brianjohn93961
                  Can these also be used as piston rings in steam engines ?
                  #828511
                    Yes they are OK for iston rings in both steam and IC engines
