cylinder material
cylinder material
Home › Forums › Beginners questions › cylinder material
  • #131973
    michael burton 1
      @michaelburton1
      hi can a steam cylinder be made out of aluminium i would be using a bronze liner obv car and bike engines are made out of aluminium but i was worried as to slide valve surface being ally and what type of meterial i should use for said valve.
      im going to the metal supplie shop tomorow and was gunna try to pick up some of the material i need the reason for using ally was i need a block 3.5'' square and it was the cheapest route
      cheers for any help
      #6903
      michael burton 1
        @michaelburton1
        #131978
          Is this for your traction engine?
          If so I would tend to say no, if just for a little stationary engine then yes
          I'd go for a block of cast iron, cost about £5 more than aluminium but you would save on the cost of the bronze liner.
          Edited By JasonB on 07/10/2013 20:55:27
          #131982
          michael burton 1
            @michaelburton1
            hi yes it for the traction engine the only reason i was going to use the liner mainly was because on the plans for the smaller version that i have scaled up used a wastited cylinder linder around the outside to direct the steam up in to the regulator chest i supose tho with abit of thinking i could redsign it to do away with this part and reposition the steam ports
            #132000
              Its more a problem of corrosion that I was thinking of.
              If your design is steam jacketed then you can still do it with a CI block and CI liner which will still be cheaper than ali/bronze. This one of mine is an iron casting with a liner cut from iron bar. You can do it by drilling two steam passages to get around the cylinder but the heating effect of the jacket is helpful.
              #132020
              Geoff Rogers
                @geoffrogers81118
                as JasonB says, corrosion would also be my main worry. Some aircraft grades of aluminium may be ok, others most definitely not.
                Steam can be a very demanding fluid.
                #132085
                nigel jones 5
                  @nigeljones5
                  to be frank – yes, no problems. Sure it will oxidise, but do you realy intend on running it for the next 120 years…thought not. Having said that, i would opt for cast!
                  #132089
                    By corrosion I was thinking more along the lines of galvanic/catalitic attack being bolted to a copper boiler with bronze fixings all in a damp warm enviroment, rather than surface oxidation
