Correcting off set deep hole
Home Forums Beginners questions Correcting off set deep hole
  • #133980
    Nathan
      @nathan
      Hi,
      I need to drill two holes in a 6" long block of aluminium.
      I have drilled the first hole 6.5mm dia. and this stayed on course without any problems. However the second hole wondered off by 2.5/3mm. This shouldn't be a problem as the finished hole needs to be 20mm dia.
      I only have a Myford ml7 and large old Drill press (which I used to drill the holes).
      My question is HOW do I straighten the second hole whilst expanding it. Due to it's length I don't want to chuck it in the lathe.
      Any ideas??
      Thanks.
      #6937
      Nathan
        @nathan
        #133987
          Clamp it to the cross slide with packing or onto a vertical slide and come at it from both ends with slot drills, finally finish with a long between ctrs boring bar.
          J
          #133988
          Peter Tucker
            @petertucker86088
            Hi Nathan,
            Try using a D bit, they are reputed to drill straight. I have never used one to correct an off center hole though.
            Best of luck.
            Peter.
            #133990
            custardcats
              @custardcats
              Nathan, you don't say what the width of the block is but if you can lay it down and clamp it onto the ML7 cross slide with the bad end facing the chuck and the good hole exactly on the Lathe centre line then try the following:
              1- Get the good hole lined up with the 6.5mm drill in the chuck (or better still a collet.) and set the micrometer dial to zero. Be sure to take up the backlash according to which way you have to go to reach the duff hole.
              2- Change the drill for a decent size end mill according to what you have – say 10 / 12mm and set it to the right centre distance from the good hole. End mill it out as far as you can go.
              3- Change the end mill for the equivalent drill and drill it out as far as practical.
              4- Do the same for the good hole.
              5- Turn it all round and do the same for the other end.
              6- Whatever you had in mind to get you to 20mm
              #134001
              Nathan
                @nathan
                Thanks for the ideas. Sometimes the answer is staring you in the face. enlightened
                Will try them out.
                Thanks again.
                Nathan.
