Compound engine
Compound engine
Home › Forums › Beginners questions › Compound engine
  • #6909
    Eric Cox
      @ericcox50497
      #132520
      Eric Cox
        @ericcox50497
        Is there a way of calculating the relationship between the HP and LP cylinders on a compound engine
        #132523
        Stewart Hart
          @stewarthart90345
          Eric
          Yes there is but you must be familiar with steam tables. If you want to take this further suggest you do a little research on thermo dynamics I have a few books on the subject but they can be heavy going depending on how good your maths and physics are. The easiest way to understand what's going on is to study some of the graphs that are published on the subject.
          Hope this helps
          Stew
          #132529
          Anonymous
            In theory it's fairly simple. Draw the pv (pressure-volume) diagram for the engine concerned, as if it had one long cylinder. The work done is the area under the pv curve. Let's consider a double compound; the pv curve is divided into two areas with a horizontal line (constant pressure). The trick is to draw the line such that the area above the line is the same as the area below the line. The area above the line represents the HP cylinder, that below the LP cylinder. If the areas are equal then equal work is done by each cylinder.
            From that the sizes of the cylinders can be calculated based on cylinder volume, stroke and the steam pressures in and out from the pv diagram. Any 'Heat Engines' from the 1930s, or 1940s, and earlier will probably have details and worked examples. There is a formula in my textbook, but it's a bit too involved to type here.
