colouring steel
colouring steel
Home › Forums › General Questions › colouring steel
  • #148364
    speelwerk
      @speelwerk
      I need to colour a small (ca.6mm diameter) knob of iron/steel in a dark rust brow oxide shade, that sounds simple but it is part of steel studwork on a very fine satinwood veneered lid and I cannot remove it without causing damage.
      I have tried a thin coat of battery acid applied with a brush and other fluids I have at hand but all gave no reaction at all after leaving overnight. I can of course paint it in a sort of right colour but would like to have something that is close to the original oxide finish. Perhaps someone can advice a simple household chemical that I can try. Niko.
      #23225
      speelwerk
        @speelwerk
        #148368
        JohnF
          @johnf59703
          Niko, Not sure where you are but I have exactly the right chemicals but it would not be possible to post them, I am in Lancashire.
          However a crude form of rust browning can be achieved with salt water, it will probably require several applications and clean off with de-greased wire wool after each coat until the desired colour is obtained. Lastly apply soda water solution to kill the rusting. [washing soda] The colour will depend on the type of steel/iron the ball is made of, steel does not brown easily, iron does.
          Regards John
          #148373
          jason udall
            @jasonudall57142
            Can I suggest a fine polish with degrease/iron wool…and turn back…seems to work for me all to frequently
            #148375
            speelwerk
              @speelwerk
              Jason, I have allready turned my back and I agree it normally works perfect and without any problems, but now after completing the turn, no effect is noted. I will try John's salt water perhaps that will have a shorter turning time. Niko.
              #148391
              jason udall
                @jasonudall57142
                Aye
                #148406
                JohnF
                  @johnf59703
                  Niko you can also try Ferric Chloride if you can get any, this is use in most of the formula use to brown Damascus gun barrels If you want a formula PM me.
                    Ferric chloride is easy to obtain from any electronic supplies company as it's used for etching PCBs. usually as dry 'crystals' (shaped like small golf balls).
                    speelwerk
                      @speelwerk
                      Thanks all for the advice, I took the risk of removing it from the lid and was then able to get the correct colour in a short time. Niko.
