Clarkson controlled spiral grinding attachment
Home › Forums › Workshop Tools and Tooling › Clarkson controlled spiral grinding attachment
  • #199946
    David Clark 13
      @davidclark13
      This item is on Ebay.
      This item
      it is a Clarkson controlled spiral grinding attachment. I did not know Clarkson did one of these.
      Check out the sellers other items. He also has a Clarkson grinder base.
      I have no connection with the seller.
      Edited By John Stevenson on 11/08/2015 00:06:34
      #17800
      David Clark 13
        @davidclark13
        #199954
        Bazyle
          @bazyle
          Not sure how you set that link but my computer thiks it's a phone number.
          Anyway I'd be interested to see how you set it up, and if the bar thing is even part of it.
          Why do sellers feel the need to put 'shed find' or 'barn find'. Sometimes they seem to be trying to excuse the fact that they are too lazy to clean the item or research what it is.
          #199958
            Posted by Bazyle on 10/08/2015 21:18:24:
            Bazyle,
            I'm happy to be corrected, but: I doubt if David 'set' anything … he probably just inserted the number.
            "Helpful" computers [including my iPad] are quite capable of "recognising" a 'phone number within plain text.
            John Haine
              @johnhaine32865
              If you copy and paste into the eBay search box it will find it but I think that number is wrong. The right one seems to be 271952951417.
              #199964
              JohnF
                @johnf59703
                Michael, my iPad like Bazyles co mutter thinks it's a phone number, find this quite a lot !
                #199965
                  Posted by JohnF on 10/08/2015 23:24:10:
                  John,
                  Yes, that's why I put "Helpful" and "recognising" in quotes.
                  Edited By Michael Gilligan on 10/08/2015 23:36:30
                  #199966
                  John Stevenson 1
                    @johnstevenson1
                    David's post edited for correct link.
                    #199979
                    Robbo
                      @robbo
                      For the general edification, here's the section from the Clarkson manual. Seems its only for the Mk2 machine.
                      #199984
                      SteveI
                        @stevei
                        the tail stock and the mounting casting for the taper setting assembly are not visible in the pictures. So I am not sure how it could be used as is without at least making a mount for the taper setting assembly.
                        For completeness there was a unit for the MKIII as well. I'd imagine that is like hen's teeth.
                        Steve
