but is the rotor safe at more then 3000 rpm?
Modern motors are built to much tighter tolerances than earlier models. Partially this is to improve efficiency, but also for “inverter rating”.
Squirrel cage motor rotors are aluminium cast onto the compressed rotor lamination pack, with the shaft then pressed though the unit & finished turned on the shaft between centres before balancing. I don’t see much room here for the rotor to come apart at high revs. Limiting factor is most likely the bearing rating and the quality of the balancing.
During the rebuild of a CNC router for aerospace machining at a former employment (wing ribs from solid billets on this machine) the spindles were basically squirrel cage induction motors with the “shaft” being the 40 ISO taper spindle held in precision angular contact bearings. Part of the rebuild was to re-engineer the spindles to fit power drawbars and increase the speed as far as possible – up to 12,000 rpm, which was the limit of the bearings & driven by Siemens inverters. The rotor castings were the originals.
In service, bearing life was around 9 months use – the machines were pushed hard, with the operators having to use a welding glove to hold cutters when they were taken out of the spindle after use. Customer had spare heads converted, so the machine could be kept running when the worn out heads were returned to us for rebuilding and running in – which took around two days to get them to run at full speed without overheating.
Nigel B.
