Carbide Tipped Tooling explained.
Home › Forums › Workshop Tools and Tooling › Carbide Tipped Tooling explained.
Viewing 23 posts - 1 through 23 (of 23 total)
  • #325860
    Chris Trice
      @christrice43267
      Found this video online which clearly explains all about tipped tooling that struck me as too good not to post for people new to the hobby. It also strikes me like a potentially good subject for the magazine.
      #18731
      Chris Trice
        @christrice43267
        #325869
        I.M. OUTAHERE
          @i-m-outahere
          Some of his videos are side splitting funny as well !
          Another carbide tooling video was made by Adam booth ( abom79 ) that from memory was made with the help of a sales rep from Niagra tooling and i found it very informative .
          Edited By XD 351 on 07/11/2017 12:34:37
          #325904
          Nick Hulme
            @nickhulme30114
            Posted by XD 351 on 07/11/2017 12:33:51:
            I love his videos and have loads of time for the guy but he will keep dropping one based on basic misunderstanding of things or poor technical terminology-
            "Mainly Tungsten and Carbide powders pressed into a shape"
            I can only guess that constant use of "Carbide" as a shorthand for "Tungsten Carbide" leads some people to think that tools are a mix of a metallic element, "Tungsten" and a "Carbide" of something entirely random or perhaps "Pure Carbide"?.
            Maybe he means "Mainly Tungsten Carbide plus other Carbides" but the terminology is such that in getting it wrong it is so wrong as to be misleading to anyone in need of a "Beginner's Guide"
            – Nick
            #325911
            John Reese
              @johnreese12848
              Tungsten carbide inserts are made from tungsten carbide and other carbides with cobalt as a binder. Proportions vary according to the application.
              #325918
              Robin
                @robin
                I thought that "Carbide" was just the new Chinese word for "High carbon steel" because they had quite worn that one out with cheap taps and stuff that shattered the moment you applied any real pressure face 22
                #325920
                MW
                  @mw27036
                  Tnere is a very very well written article by a guy named mike Haughton which has just come out this month, all about carbides of all stripes. I wouldn't miss it. Hats off to him.
                  Michael W
                  #325950
                  jimmy b
                    @jimmyb
                    +1 on the article in this month’s MEW. Very well written
                    Jim
                    #328596
                    I.M. OUTAHERE
                      @i-m-outahere
                      And for those who have ever wondered how they are made .
                      #328597
                      Chris Trice
                        @christrice43267
                        Interesting.
                        #329091
                        OuBallie
                          @ouballie
                          Recommendations please on which type of holder and insert/s to use on my BH600G, for basic turning using most grades of metal we hobbyists use.
                          Geoff – That TuffSaws 10/14 blade is GOOD!
                          #329182
                          I.M. OUTAHERE
                            @i-m-outahere
                            Hi Geoff,
                            I usually use use an insert with a W for the first letter ( trigon shape ) for heavy or intermittent cuts and an insert with a T as the first letter ( triangle ) for general work .
                            The tool holder dictates the rest of the code ( other than chipbreaker style , grade and coating) like hole type ,clearance angle and size etc so you need to sort out the size of holder your lathe needs and then decide on insert shape .
                            Most people just buy a set of toolholders from a supplier then go from there and some sets use the same insert on all the holders so you only need one style of insert which for most users is very convenient .
                            Ian
                            #329190
                            nigel jones 5
                              @nigeljones5
                              Posted by XD 351 on 23/11/2017 02:02:58:
                              very interesting, no wonder they aint cheap
                              #329203
                                Posted by fizzy on 26/11/2017 08:32:09:
                                The video that popped up after XD's recommendation is well worth watching too. About 30 minutes for hobbyists. A good explanation of HSS vs Carbide and the Pros&Cons of Brazed Carbide tools (beginner avoid). Finishes with an explanation of insert code numbers and why you might choose round, trigonal, triangular, square or rectangular inserts. Ends with a demo of an insert producing a carp finish with shallow cuts at low feed rate moving to perfect finish with a much deeper cut at a higher feed rate. Lesson learned: inserts are 'better' than HSS only if you drive them right! Makes the interesting comment that professional buyers ring up the rep and tell him the material being cut and the machine that will be used. The rep selects the best insert for the job and sends the invoice to someone else. Amateurs have to do their own research and pay the bills.
                                I liked the bit at the beginning where he machines HSS with a carbide cutter but the message is balanced. He follows up with good reasons for using HSS rather than carbide.
                                The humour might not be to everyone's taste. Be warned – I liked it!
                                Edited By SillyOldDuffer on 26/11/2017 10:19:02
                                #329218
                                OuBallie
                                  @ouballie
                                  Thanks Ian.
                                  Will check advertiser's offers.
                                  Dave,
                                  Watched that one as well and enjoy his humour.
                                  Geoff – New router up and running.
                                  #329225
                                    Posted by OuBallie on 26/11/2017 11:37:25:
                                    Dave,
                                    Doh, I've just realised that the link I posted is exactly the one Chris started the thread with. No idea how that happened. Feeling foolish…
                                    blush
                                    #329233
                                    Harry Wilkes
                                      @harrywilkes58467
                                      I too am fan of 'This Old Tony' admire his skills but also enjoy the humour he injects into his video's
                                      H
                                      #413734
                                      Terry Kirkup
                                        @terrykirkup37827
                                        Hi Gents/Ladies. You folk will know all of this but I'm just a few months in as a lathe owner. I've been tooling up since Christmas and can now do simple lathe work. I dived straight in with a Chinese QRTP and indexable tools and it's been like a drug. I just thought I'd share this in case it hasn't been let out on here. Although I have very limited understanding of most of it, it still has me completely mesmerized!
                                        mark costello 1
                                          @markcostello1
                                          OOOOHHHHH it starts again. Welcome to the chip making asylum.
                                          #413746
                                          Terry Kirkup
                                            @terrykirkup37827
                                            haha, cheers Mark
                                            #413750
                                            old mart
                                              @oldmart
                                              Fortunately for people who want to try indexable tooling now, the affordable Chinese inserts and holders have improved greatly recently. I have stuff from all the major manufacturers as well as Chinese, and for hobby use, the cheap stuff from ebay is well worth the money. The only hss I have used on a lathe in the last ten years is in the form of twist drills.
                                              #413792
                                              Terry Kirkup
                                                @terrykirkup37827
                                                Hi old mart, good to hear your views. For what it's worth with my very limited experience, the Chinese stuff is doing everything I need it to do and the Banggood drills I got are superb, every bit as good as the Milwaukee and DeWalt stuff I've used for years, even on stainless. I'm also more than happy with the Warco 290 lathe I bought, absolutely no complaints. The only regret I have is that I don't have the time to start making models, especially after visiting the wallet-sucking Doncaster show!
                                                #413811
                                                Blue Heeler
                                                  @blueheeler
                                                  Thanks for the thread.
