Caradoc by John Haining
Home › Forums › Traction engines › Caradoc by John Haining
  • #137638
    space decks
      @spacedecks86530
      I am nearing completion of John Hainings 2" scale Caradoc steam tractor for use as a DeWinton type 7, 7/4 0-4-0VB loco.
      When I assemble the engines and rotate the crankshaft, the end of the piston hits the rear cylinder cover.
      Ive checked everything, but its as if the engine centres are slightly too close, but are not when Ive checked this.
      Has anyone had similar problems? The problem comes down to about around 1/16". But enough!
      Cheers
      #2783
      space decks
        @spacedecks86530
        clearance problems
        #177603
        roy williams 3
          @roywilliams3
          hello has anyone any info on building the caradoc steam tractor problems etc
        Home › Forums › Traction engines › Topics
