captive gauge glass valves
Home Forums Beginners questions captive gauge glass valves
  • #186958
    Metatsteam1
      @metatsteam1
      Can anyone help with links to drawings for modifying published gauge glass/ blower valve design's to the type that cannot be screwed out when in steam. I have thought of a couple of ways to modify them but would like to see if there is a standerd way that is acceptable to the boiler inspector.
      Matthew
      #7579
      Metatsteam1
        @metatsteam1
        #187030
        julian atkins
          @julianatkins58923
          hi matthew,
          ive sent you a PM.
          cheers,
          julian
          #187275
          duncan webster 1
            @duncanwebster1
            If your inspector is failing a boiler because it doesn't have captive valves he is exceeding his authority. This was discussed in ME some time ago.
            #187283
            Metatsteam1
              @metatsteam1
              Hello Julian
              Sorry but I'm not sure what you mean by PM
              Hello Duncan
              Thanks for that. I was under the impression that they were a requirement now. I have not had chance to speak to whoever will test my boiler yet but I intend to fit captive valves as I think they are a good idea.
              Matthew
              #187284
                Matthew, if you look along the top of the page in the green bar you will see "inbox" click that and you will see any Private mesages. There will also be a flashing envelop in the top right under my friends which will also open your messages
                Edited By JasonB on 21/04/2015 20:17:51
                #187418
                Metatsteam1
                  @metatsteam1
                  Thank you Jason . I hadn't noticed the bar at top of the page.
                  Hello Julian
                  Thank you for the link to your photos. My idea is to increase the thread size then reduce the spindle diameter and fit a gland nut that will prevent the valve screwing out. This looks ok when drawn, I` ll have to make one to see if it looks right.
                  Matthew
                  #187421
                    Just a random thought. Should the gland nut have a finer thread than the valve spindle, to stop them unscrewing together?
                    julian atkins
                      @julianatkins58923
                      hi matthew,
                      what you propose is as neil suggests not a good design. you need instead a double ended female connector that restricts the spindle from being unwound and into which the spindle is screwed.
                      both my last 2 locos have all captive fittings as per the 'advised' section of the boiler regs. the regs are a bit silly as 'advised' for backhead fittings, but ive made the boiler blowdown valves all captive as well though on one loco the boiler blowdown is on the backhead and on the other on the sides of the boiler.
                      captive valves require a bit of extra work as the 'squre' for the fitting of the handles must of necessity be smaller so this involves a bit of fine work and close tolerances, and the concentricity of the parts is crucial to good and reliable operation.
                      however i have also seen idiots unscrew blower valves completely with dramatic results, so well worth the extra effort IMHO.
                      cheers,
                      julian
