calculation for nod on milling machine
Home › Forums › General Questions › calculation for nod on milling machine
  • #25921
    paul rayner
      @paulrayner36054
      #348571
      paul rayner
        @paulrayner36054
        Hello all
        I've just got round to installing my new super major milling machine (I had it delivered last dec). A few small problems with it but I have got them all sorted apart from the nod. I've got +0.09mm on the inboard side and -0.08mm on the outside over a 100mm radius. The X axis is now bob on. Question is how do you calculate the size of the shims I need to put under the column? I know I will still have to measure it after but it would be better if I had a ball park figure to start with.
        Thanks all in advance
        Paul
        #348577
        Clive Foster
          @clivefoster55965
          Assuming you have holes in the shims for the bolts to go through.
          Ratio of the shims to your measured error is the same as the ratio of the measurement diameter to the bolt spacing.
          Measured 0.17 mm error in 200 mm so if bolts are 100 mm apart you need 0.085 mm / 3.3 thou of shims.
          Edited By Clive Foster on 02/04/2018 22:38:06
          #348717
          paul rayner
            @paulrayner36054
            Thank you Clive I will go and measure my bolt spacing
            regards
            Paul
