Buying a mill – What basic Toolkit?
Home › Forums › Beginners questions › Buying a mill – What basic Toolkit?
Viewing 12 posts - 26 through 37 (of 37 total)
  • #324444
    Vic
      @vic
      The six most often things used on my mill are:
      Machine vice
      ER32 collet chuck
      Parallels
      Drill chuck
      Copper and hide hammer
      One inch paint brush for clearing scarf
      #324483
        Posted by Jon Gibbs on 30/10/2017 09:56:22:
        I'm really interested in these posts – there's certainly more than one way to skin this particular cat.
        True of anything in engineering. That's why personal preference should not be underestimated as an important factor.
        For example I use my clamp set regularly.
        I have made t-nuts with undersize M6 threads for small items.
        Dave Halford
          @davehalford22513
          Till you know want you want to make.
          3" vice -bog standard machine vice not a wobbly tilting one. Make it's locating blocks for your first project
          Cutter holder – Vertex Osborn clone suits me as you don't have to wang it up very tight and I have a load of threaded cutters, others like ER versions for plain cutters.
          tee nuts can be 60p each at Warco – pairs of clamps are best from RDG – buy extras at an ME show. Get some decent threaded rod in whatever size fits your table slots.
          Parallels – small thin ones, lathe tool blanks will do for thick ones.
          That covers the two primary objectives.
          • holding the work still
          • holding the cutter
          The rest is nice to have which you may never use..
          #324583
          Mike Poole
            @mikepoole82104
            A dial indicator has to be an essential as a vice will certainly need to be set true to the machine axes and even a clamp setup may have pre machined faces to set up. The head of the mill may need tramming if it is moveable or if the column is bolted on.
            #324592
            Vic
              @vic
              Posted by Mike Poole on 31/10/2017 09:21:58:
              I was shown how to get the head of a mill vertical with a long bent rod and a fag paper! Half a thou over 30 inches is close enough!
              #324593
              David Standing 1
                @davidstanding1
                Posted by Muzzer on 30/10/2017 12:31:10:
                Posted by Andrew Johnston on 30/10/2017 10:49:26:
                Clamp sets – you can never have enough sets, I have 3x½" for the surface grinder and lathe faceplates and 4×5/8" for the mills. Places like MSC have special offers, around £30 per set
                Indeed – currently MSC has the generic "52 piece clamp set" on offer at £30 or so (look at the last page of this month's offers shown in the link). I got a (second) set from them recently and they are pretty decent. It would cost you more than that in cutters to "just make your own". Apart from the myriad clamps themselves, there is a useful selection of tee nuts and bolts that are useful for holding down vises etc. I seem to manage 90% of my work in the machine vises. Either way, the table has tee slots, so you are going to want a set of tee nuts and bolts…
                Murray
                Murray
                I was going to grab one of those – but the offer expired on 27 Oct sad
                #324595
                Danny M2Z
                  @dannym2z
                  Posted by Vic on 31/10/2017 09:59:37
                  Indeed it is Vic; So could you please give a bit more info as I am sure that I am not the only interested person here.
                  * Danny M *
                  #324603
                  Anonymous
                    Posted by David Standing 1 on 31/10/2017 10:09:25:
                    I was wrong, I've got 5 sets of the 5/8" clamps.
                    I wouldn't worry about the offer expiring; I'd be pretty surprised if it wasn't in the next flyer as well. The items on offer from MSC don't seem to vary much from flyer to flyer.
                    #324613
                    Mike Poole
                      @mikepoole82104
                      Posted by Vic on 31/10/2017 09:59:37:
                      I suppose essential is an over emphasis but it does make life easier
                      #324644
                      David Standing 1
                        @davidstanding1
                        Posted by Andrew Johnston on 31/10/2017 11:01:28:
                        I've already checked the November flyer, only the 5/8 ones are on offer (my Warco mill is 12mm).
                        But, they have some good offers, I am sure you are right that they will appear again, and I have signed up for their newsletter; so thanks for that smiley
                        Edited By David Standing 1 on 31/10/2017 13:46:40
                        #324648
                        Anonymous
                          Must be higher quality fag papers, as mine measure 1 thou thick. wink 2
                          #324682
                          Mike Poole
                            @mikepoole82104
                            I would imagine a feeler of any thickness can be used with a bent rod just keep adjusting until you have the same feel in each extremity.
