Bronze wire, where to find
Home › Forums › Beginners questions › Bronze wire, where to find
  • #78329
    Goran Hosinsky
      @goranhosinsky61367
      Tubal Cain in his books “Simple model steam engines” uses bronze wire for making springs. I have searched the Internet but have not been able to find a source for small quantities.
      Any recommendations on where I can buy this wire by mail?
      Goran
      Canary Islands
      #5763
      Goran Hosinsky
        @goranhosinsky61367
        #78330
        David Littlewood
          @davidlittlewood51847
          Goran,
          You will have more success if you search for “phosphor bronze wire”, since that is the metal usually used for spring making. For example, eBay shows a good range: Wire
          Hope the link works, if not just google it, which will throw up many more as well.
          David
          #78336
          David Littlewood
            Goran,
            An additional thought – unless you are only using very fine wire, you would be well advised to get a spring winder. This is a tool to feed the wire on to the rotating mandrel, to avoid damage to your fingers, and to help get even spacing of the coils. See for example Hemingway Spring Winder . Be aware this is a kit not a finished tool, though it’s not difficult to make (I made one a couple of years ago).
            David
            #78339
              Reeves do bronze spring wire in a few different gauges
              J
              #78403
              Robert Dodds
                @robertdodds43397
                Goran,
                Beryllium Copper is the ideal spring material. It has both anti corrosion and good electrical conductivity as well as a relatively high modulus for elasticity.
                Do you know what dia wire you want?
                I’ve got some 0.028″ dia if of any use
                Bob
                #78412
                Terryd
                  @terryd72465
                  Hi Goran,
                  Macc models sells suitable wire here. He is usually cheaper than other suppliers (especially Reeves) and is reasonable on his postal charges.
                  Terry
                  #78460
                  Chris Banninger
                    @chrisbanninger89672
                    Posted by Robert Dodds on 23/11/2011 10:41:28:
                    Goran,
                    Bob
                    #78472
                    John McNamara
                      @johnmcnamara74883
                      Hi All
                      Handling Beryllium requires care……
                      cheers
