Brazing cast bronze
Brazing cast bronze
Home › Forums › Beginners questions › Brazing cast bronze
  • #6692
    JamieG
      @jamieg
      Is it possible to braze/solder cast bronze in your own workshop?
      #118344
      JamieG
        @jamieg
        Hi there,
        I received a question from a colleague asking if it is possible to braze/solder a broken cast bronze chandelier.
        My first thought is yes (haven't seen the offended part yet). I guessed this could be an interesting argument and possibly get your idea and what type of fluss and rod to use (if brazing is possible at all).
        Thanks,
        Giacomo /Sweden
        #118367
        Sub Mandrel
          @submandrel
          You can silver solder it, proper brazing may be going too far. Choose silver-flow type rods.
          I have successfully silver soldered brass many times, even a cast door-handle.
          JamieG
            @jamieg
            Thank you Neil for the tip.
            Let see the result.
            Giacomo
            #118409
            MICHAEL WILLIAMS
              @michaelwilliams41215
              Neil is quite correct about bronze and brass being easy to silver solder by ordinary means .
              There is a possible difficulty though in that the cast bronze may not be cast bronze . Cast bronze is generally used for more sophisticated higher cost work . Cheap stuff is more usually made from any one of many economy alloys – sometimes plated or chemically patinated to look like bronze .
              These are sometimes called in the antique trade spelters or base metals – though neither is correct .
              The economy alloys are at best high zinc brasses and at worst melted down sweepings from the foundry floor .
              Need to test what you've got before attempting silver soldering – some of the really poor alloys just crumble away when heated .
              Genuine bronze is very coppery in colour and fine grained . Brass looks like brass . The rubbish metals are usually very yellow and with noticable coarse grain structure and flaws . Need to look at a newly fractured or cut surface to avoid being misled by oxidation or surface treatment ..
              Michael Williams .
              PS: Not that common – but there are other series of metals for ' brassware ' goods based on Tin/Lead alloys and even cast iron . Surface colouring can be quite good on some of these but the appearance of a newly cut surface is usually a dead give away .
              Edited By MICHAEL WILLIAMS on 04/05/2013 15:36:11
              #118434
              JamieG
                @jamieg
                Good point Michael.
                Haven't examined the broken part yet. From the description I got the surface is rough like broken casted iron.
                I have the feeling that it might not be an easy fix.
                Giacomo
                #118438
                Sub Mandrel
                  @submandrel
                  If Michael is right it might be a job for THIS (not the clutch!)
