Boxford missing a Nut
Home › Forums › General Questions › Boxford missing a Nut
  • #474311
    Chris George
      @chrisgeorge68271
      So I finally jumped in and brought myself a Boxford Lathe, and currently just fixing all the issues. Managed to figure out how to take the play out the cross slides etc.
      However just notices a small bolt missing. The thread is a little damaged but looks like it could be a M6x1.25. But as it’s a British machine made in 1952 I’m surprised it’s metric?
      Anyone have any pearls of wisdom or knowledge they can shine on the situation.
      #27391
      Chris George
        @chrisgeorge68271
        #474312
        Keith Long
          @keithlong89920
          More likely 1/4in BSW (20tpi)
          #474325
          old mart
            @oldmart
            Take the handle off to expose more thread. It could be 1/4 BSF, or 1/4 UNF even, as the lathe is a South Bend clone.
            #474350
            Pete Rimmer
              @peterimmer30576
              It's a 1/4" BSW round nut with a slight dome top and a slot across it. You need a screwdriver with a slot ground in the middle of the blade to tighten it.
              #475068
              Sam Spoons
                @samspoons83065
                It is indeed ¼" BSW, mine has a narrow 'locknut' style nut on it. I know as I had to source one for the top slide.
                How are you going about removing backlash, I'm having trouble with mine on both cross and top slides and tailstock?
                #475073
                Oldiron
                  @oldiron
                  Agreed it is1/4 BSW nut with a rounded head. I made one for mine from a standard nut and turned it down to the required dimensions.
                  regards
