After 40+ years, still have not found any desparate need for a Q C T P.
They were originally intended, as their name suggests, for quick changing of tools on production work, where time is money. Holders from one version are unlikely to fit a post from another!
For the hobbyist, very often the machine is not sufficiently rigid to maximise the benefits of the sort of speeds, feeds, and cuts needed in industry, to minimise process time.
You might be better making a rear toolpost for the lathe. (I went mad and made a 4 way rear post, so that the front post carries Rougher, Finisher and Boring tool, while the rear post carries front and back Chamfer tools and a Parting tool.
A parting tool, obviously mounted inverted, in the rear post makes parting off much less fraught.
In any case, before launching into a load of accessories, get to know the machine. Otherwise you might find that you have bought gadgets that you very rarely, if ever, use.
Use the machine to make simple tools that you WILL use; Centre Height Gauge, Tailstock Sliding Die Holders, and using a suitably mounted drill chuck, a Sliding Tailstock Tap Holder.
(The Tailstock does not slide, the Holder slides on an arbor held in the Tailstock)
Holding the Tap in a drill chuck will prevent some broken Taps, by letting the Tap slip, if things get tight, rather than breaking and converting the workpiece into scrap.)
As they say in Suffolk, “Make haste, slowly”. Take time to be become familiar with the machine and it’s capabilities. By then, you might have found some accessories that you DO need.
Just cut some metal to find what the machine, and you, can do, before launching into something complicated.
As you gain experience, so will your confidence, and your ability to plan and execute work.
You won’t be the first person to find themselves with a half finished job that can no longer be held for further operations!
