Anyone know about Mitsubishi plcs
Home › Forums › General Questions › Anyone know about Mitsubishi plcs
  • #439899
    Ian Parkin
      @ianparkin39383
      Has anyone any experience with Mitsubishi plcs
      i have 2 machines both very different which have both got the same problem
      the plc isn’t running and the prog light is flashing.
      both batteries were long dead operators say they been like that for years.
      i have replaced battery’s so that error has gone
      both machines have operated for years perfectly well one for 25 years the other 15 years
      do they lose the program? Is that what’s happened here?
      #26988
      Ian Parkin
        @ianparkin39383
        #439908
        Mike Poole
          @mikepoole82104
          It’s a near certainty you have lost the program, do you have a backup and the means to load it? A paper listing would be the minimum help but manually entering it all is tedious.
          #439910
          Ian Parkin
            @ianparkin39383
            no nothing…. backup or means
            just strange that 2 machines in different locations have done the same within days of each other after working fine for years
            just coincidence?
            we will have to get machines agents in
            Edited By Ian Parkin on 02/12/2019 21:15:17
            #439911
            S.D.L.
              @s-d-l
              Which PLC models are thet F1, F1x or rack based.
              If Block F series and no memeory module then no battery and power off = programe lost.
              Steve
              #439912
              Ian Parkin
                @ianparkin39383
                Steve
                i’m sure that the battery’s have been totally flat for years
                the dates on the ones i removed were 95 and 03
                machines been switched off every night for years
                #439913
                Ian Parkin
                  @ianparkin39383
                  They are fx series
                  #440172
                  S.D.L.
                    @s-d-l
                    There isnt a run / program swith cthats someones moved.
                    I cant remember if FX are set to run in software or by switch.
                    Getting agents in sounds best bet as you said.
