A New Use fior Digital Verniers??
Home › Forums › Workshop Tools and Tooling › A New Use fior Digital Verniers??
  • #215594
    Dave Powell 2
      @davepowell2
      Has anybody taken apart one of the cheap digital verniers to convert it as a dro for a lathe or milling machine? I kind of strikes me that it would be quite a cool thing to do. I will be purchasing one at some point to see if it is possible but just wondering if somebody else has beaten me to it.
      #17919
      Dave Powell 2
        @davepowell2
        #215596
        Howi
          @howi
          Not much point really, as the igaging scales are cheap enough and designed for the job.
          But, of course , if you want to have a go……………teeth 2
          I have adapted a cheap digital caliper from maplins, to give a readout from my lathe tailstock, just a case of chopping bits off rather than adapting electronically though.
          Edited By Howi on 08/12/2015 17:27:21
          #215597
          Brian Wood
            @brianwood45127
            Hello Dave,
            Sadly not a new idea, many others have thought the same. I have one on the tailstock ram on my Myford, there is a proper DRO system on the lathe itself.
            Machine DRO sell stripped down versions without the calipers for just such applications.
            #215606
            Les Jones 1
              @lesjones1
              I've used them for the Y axis and the quill on my X3 milling machine and the cross slide on my lathe. I did also have a cut down 4" digital caliper on the compound slide but I removed it as it sometimes got in the way.
              Les
              #215607
              mechman48
                @mechman48
                I use a digital tyre gauge on my tailstock, cost me about £6 on the usual auction site, fitted magnets on the back, have taken the back stop of the slide & can get up to 37 mm readout also used it on the saddle when machining a specified shoulder length.
                George
                #215609
                Dave Powell 2
                  @davepowell2
                  Thanks for all the replies, gentlemen. I am definitely going to have a play with one but will also have a look at what is commercially available.
                  #215616
                  John Stevenson 1
                    @johnstevenson1
                    Take a look at this.
