As stated above depends what you are machining, accuracy required, shape before and after machining, etc..
But, as a generalisation, what about some variation of:
Position one end of work conveniently for machining.
Machine as required.
Bolt a fixed block to the table hard against end or some similar feature(s). Add more blocks as required against work-piece to define position.
Remove work-piece and change end for end butting un-machined end or features against your fixed blocks.
Remove 'datum' blocks.
Machine to same settings as first end.
btw Nice steam-punk avatar!
Phil
