bunging up hole in CI
Home › Forums › Beginners questions › bunging up hole in CI
  • #395951
    Alan Wilkinson 1
      @alanwilkinson1
      What is the best way of plugging it ? make a Ci screwed plug and silver solder or a steel one and solder that which could then be peened over if it leeks. the hole is 4mm
      #9530
      Alan Wilkinson 1
        @alanwilkinson1
        I have miss drilled a steam hole in CI block
        #395962
        Brian Oldford
          @brianoldford70365
          What item is it going in to? Does it need to colour match?
          #395964
          Alan Wilkinson 1
            @alanwilkinson1
            the drilling was for asteam way so nothing going in. it will be painted over so matching is not an issue.
            #395969
            Rik Shaw
              @rikshaw
              I have this problem fast approaching but I intend using JB weld to fill the 'oles. I am also going to experiment using high build primer on the castings to – hopefully – smooth out some of the imperfections on some of the castings.
              Rik
              Edited By Rik Shaw on 12/02/2019 16:27:00
              #395970
              Buffer
                @buffer
                Having gone to the effort of making the hole Is it worth keeping the spare hole.
                #395994
                mechman48
                  @mechman48
                  I have used 2 part epoxy resin + cast iron filings / machined dust collected over a period of time; simply mix the resin & dust / filings together, fill the hole, ensure that you can get any residual air out of the hole, let it set overnight. Once set file / machine off level, worked fine for me on my S10V casting void.
                  George.
                  p.s. threw the spare hole away, couldn't find a use for it.
                  Edited By mechman48 on 12/02/2019 19:31:12
                  #395997
                    Seems like a simple case for a screw thread and some high temperature sealant – loctite or similar.
                    Enlarged and a cone with a coned screw – a bit like vehicle brake bleeds – might be a suitable. Any filler over the recessed item would suffice to cover the remaining surface before surface coating. Depends a lot on the depth/ space available/etc.
                    #395998
                      To plug the blind end of steam passages I tap them 40tpi and then turn and thread the end of a bit of matching material. Apply JBWeld and then screw in the plug until tight against where the make thread ends. Saw off once set and mill or file flush.
                      One here pluging the governor passage on the flat surface above the valve chest
                      #396019
                      Alan Wilkinson 1
                        @alanwilkinson1
                        will not silver solder be ok make a cast iron screwed plug then solder it???
                        #396030
                        IanT
                          @iant
                          Cast iron is tricky to silver solder Alan – it can be done but it's not easy because the graphite content stops the solder 'wetting' I believe. I've never silver soldered or brazed a casting myself (as yet) – but many years ago the welding instructor at Maidenhead Tech bronze brazed a large cracked casting for me – and I can still well remember the swearing that accompanied the work. He managed it in the end but he said afterwards that it was a real b****!
                          I'd stick with Jasons' suggestion and use a screwed plug and JB weld – then just machine it smooth. Loctite works well when there's no heat involved but JB Weld will hold up better for this application.
                          IanT
                          Edited By IanT on 12/02/2019 23:30:40
                          #396043
                            Silver soldering a plug into a large CI casting will be challenge as you need to get a lot of heat in and joint prep is important. A high temperature retainer will be fine.
                            Alan Wilkinson 1
                              @alanwilkinson1
                              Thanks to you all I have now ordered some JB weld and will go with your seggestions thank you.
                              Edited By Alan Wilkinson 1 on 13/02/2019 12:05:17
