Selecting a VFD for a Harrison lathe.
Home Forums Beginners questions Selecting a VFD for a Harrison lathe.
Viewing 25 posts - 1 through 25 (of 57 total)
  • #379113
    Daniel Grant
      @danielgrant15006
      Hello all
      I could really use some help understanding VFD’s. I have recently bought a Harrison 140 from a school and it runs on 3 phase, and 380v. The lathe came with a pillar drill that is also 3ph, but seems to run on either 220v or 380v.
      Here are the questions I have:
      1. I’ve been told it’s essential to match the VFD to the motor, but I can’t find a VFD that outputs 1.1kw the lathe requires, do I just have to exceed it?
      1. Is there an advantage to running the pillar drill on 420v over 240v as I can’t find a VFD that takes 220v to 380v and can output 250w. Most seem to start at 1.5kw and are twice the price.
      Many thanks
      Dan
      #9399
      Daniel Grant
        @danielgrant15006
        #379114
        Daniel Grant
          @danielgrant15006
          If it helps here is the info from the label on the motors:
          Lathe motor:
          Class E
          Frame: 66A
          Volts: 380-420
          Ph:3
          F.L Amps: 3.0
          F.L speed : 1400
          Hz: 50
          Rating: cont
          Kw: 1.1
          Pillar drill motor specs
          Class: E
          Ph:3
          Watts:250
          F.L Amps : 1.2 or 0.7
          A label that’s been worn reads : 240/420-460/ 1740 / 60hz
          Voltage: 220 or 380-420
          F.L speed: 1440
          #379118
          John Haine
            @johnhaine32865
            When it says the lathe runs on 380V, that's the phase-phase voltage. Phase to neutral is 230V. You need to determine if the motor is star or delta connected – if it is star then it may be able to reconfigure the terminals for delta to run off a standard VFD. There is probably a covered terminal block on the motor, if you can remove the cover and take a photo and post it here we can say more.
            There is no problem using a VFD that can output more power than the motor needs. Usually there is a programmable current limit that can be set to match your motor.
            The pillar drill motor can probably be wired star or delta so you can run it from a standard VFD. Again a photo of the terminal block would help.
            #379125
            Brian H
              @brianh50089
              Have a word with http://www.drivesdirect.co.uk/. Usual disclaimer but I found them very helpful and knowledgable with running my Alexanda T&C grinder which is fitted with a dual voltage motorBrian
              #379135
              Jon
                @jon
                1.1kw seems very little on the 140, most are 2.2kw 3ph 400v.
                Since its a massive case size has to be 14" dia on my old 140 1 1/2hp 1ph 240v, i would be tempted as the easy way out to change the motor for a 3hp 3ph dual voltage modern type but be prepared to make or modify the plate mountings and or the 2 pulley belts.
                Whilst here my old 140 used to draw at least 13A 240V on startup. Old motor probably needed rewiring etc = not worth it when can get modern new for same price or less.
                Running it in VFD config will still be able to control by the clutch with no faffing about of any feedback wires to invertor.
                Inverters do exist to run 400v from 1ph 240v, the way my M300 runs the last 8 years, but it will cost big time.
                #379142
                john fletcher 1
                  @johnfletcher1
                  Several of my friends bought Huanyang inverters and I wired them up, very easy. One lathe also came from a school and it to was a Harrison 140 nice machine. I made a remote such that they could us the existing controls. There is a thing on Utube showing some one doing the programming, which later I copied, to late for me as I had managed without. The motor terminal block was easy to alter, just moved the links and the coolant pump I wired a 4 micro farad capacitor across a pair of terminals, so now it runs from a 13 amp socket. I did wire a contactor BEFORE the inverter to give No-volt release. The capacitor was from an old fluorescent light fitting. Some of the inverts came from Leicester others from Germany. Be quick with Germany ! Nearly forgot ,inverters cost from £98 to £120 for the same thing and are still working 4 years later. John
                  #379150
                    The "Voltage: 220 or 380-420"
                    means you can easily rewire it as delta or star. There should be moveable bars (and usually a sticker showing the arrangements) in the terminal box.
                    (Sorry for the SHOUTY font)
                    #379508
                    Daniel Grant
                      @danielgrant15006
                      Ib0491285-d863-4565-9f52-aa3a781ee3b7.jpeg82240fec-d636-43d7-a670-b291996d0b1b.jpegThank you all for your advice, I’ve done a little reading around delta and star configurations and the motor wiring doesn’t look like either! I’ve tried to add a few pictures, one of the terminals on the back of the motor, one of a sticker inside the motor casing and one of the new lathe (with my previous lathe in front!) From looking online the lathe looks much more like a Harrison L5 than a 140, not too sure about that 2a027698-6f3c-456a-97eb-4011314b5c27.jpeg
                      #379520
                        The lathe is wired star and the star point is inside the motor. Unless that star point can be broken and new leads brought out to those connections, it will require a 230 to 415 inverter. Likely cheaper to fit a new motor wired delta and buy a far cheaper 230V output VFD.
                        The pillar drill can be changed to delta, by changing bridging strips, if wired star. It could then be run from a 230V output VFD.
                        #379548
                        Kettrinboy
                          @kettrinboy
                          Your lathe looks to be a 140 and not an L5 , while the bed and carriage are similar looking between the two machines the headstock on a 140 is a different shape, ive got an L5 btw.
                          regards Geoff
                          #379554
                          john fletcher 1
                            @johnfletcher1
                            I'll try and send you a copy of talk (the text) I gave to the club on what you are looking for. regarding altering the motor. John
                            #379557
                            john fletcher 1
                              @johnfletcher1
                              Back again Daniel, send me a PM, can't find how to contact you. It might be tomorrow now . John
                              #379564
                                Being electronic VFDs are likely to get more capable and/or cheaper over time. It pays to keep an eye on what's currently available because I was going to tell Dan what he wanted is a bit special and a bit expensive. Actually buying a suitable VFD appears to be much easier and less costly than it was last year! A couple of minutes on ebay found this cheap example for £94.99
                                Edit: link to ebay got mangled.
                                Edited By SillyOldDuffer on 07/11/2018 10:14:43
                                #379811
                                Daniel Grant
                                  @danielgrant15006
                                  I think I’ll give Direct Drives a call tomorrow. Digging around on eBay I came across VFDs claiming to switch from single to 3 phase, and increase the voltage from 220 to 380 for £64. A compariable one from DirectDrives was almost 10 times the price, I’m a little concerned the eBay price has to be too good to be true!
                                  John – I’ve dropped you my E-mail address on a OM
                                  Thanks again for all your help.
                                  #380060
                                  norm norton
                                    @normnorton75434
                                    Daniel
                                    The 140 is a lovely lathe – well done getting it. I hope you have got the tailstock as well and the big 4-jaw chuck that the school might have had. The 140 was Harrison's later, metric version of the LS5.
                                    I fitted a metric shaft 1.5kw 240c 3 phase motor to mine. I just cannot remember if I had to modify the pulley bore. I have feeling it went straight on the new motor. The motor fitted the existing lathe frame with just some 2" sleeves and longer bolts to raise the motor. This all suggests that Harrison had fitted a modern spec motor. Measure your existing motor's shaft diameter.
                                    I went to Newton Tesla and bought the motor, Mitsubishi VFD and a dongle controller together. It will cost you bit more than shopping around on eBay but you will have a nice system with start/stop, forward/reverse, jog/run and speed all on the controller in front of you. If budget is an issue then go it alone but you need to be confident in your abilities in programming and handling hefty voltage wiring. You MUST NOT start/stop the motor by breaking the supply into or out of the VFD. Wire the VFD directly to the motor and do not use any of the Harrison control switches.
                                    I actually fitted a 2-pole motor (rather that the usual 4-pole) as it gives me the possibility of double the usual lathe speed. The 140s were built for it and you can get front plates that show the doubled gearbox RPM. To be honest I rarely use the higher speed, but I do run the lathe a half motor speed most all of the time and it is much quieter. The motor is perfectly happy for the usual light and moderate load jobs.
                                    You can get some extra change wheels and will be able to cut all the imperial threads directly from that metric gearbox.
                                    Edited By norm norton on 10/11/2018 11:22:31
                                    #380067
                                    Nigel Bennett
                                      @nigelbennett69913
                                      Speak to the chaps at Transwave – advert on the right somewhere. Really helpful guys who know their stuff. I've bought two VFDs off them for a S7 and a Boxford 280. I've also heard good words from Newton Tesla as Norm says above.
                                      #380068
                                      Ian P
                                        @ianp
                                        Posted by SillyOldDuffer on 07/11/2018 10:13:09:
                                        Surely the picture shows the input voltage range, If it generates 380V from 220 its the bargain of the century!
                                        Ian P
                                        #389324
                                        Daniel Grant
                                          @danielgrant15006
                                          Two months on and I’m still not there with this lathe!
                                          Since the last post I have bought a 2.2kw (3hp) VFD which incorrectly claimed to increase the voltage to 380v. I then bought a single phase 2hp motor, but it vibrated so much on the bench tools fell off the wall! Yesterday I collected a 3hp, 3 phase motor with the view to use it with the VFD. Unfortunately when connected tthe VFD it turns a couple of revolutions then spits out an Error 1 code (short circuit / current overload)
                                          I checked the resistance between U1-U2, V1-V2 and W1-W2 and they were all between 2.1 and 2.4 ohms. There was no connection between U,V or W or to the casing. Any thoughts on what could be happening?
                                          When I went to view we weren’t able to get the motor running using a 220v supply and capacitor, or by connecting U to Live and V and W to Neutral without the capacitor, because of this the chap I was buying from gave it to me for free, so I’m not too concerned about opening it up if necessary. Below is the current configuration of the bridging bars
                                          Any thoughts or advice would be much appreciated.
                                          Dan
                                          #389335
                                          John Haine
                                            @johnhaine32865
                                            Looks like it's delta connected as it needs to be. The winding resistances are really irrelevant except that they all about the same and there isn't a short to the frame. The current is determined by the winding inductance, not DC resistance. Quite possibly the current limit on the VFD is being triggered by the startup inrush of the motor, it would need properly configuring to set this up. Looks like a good find for free!
                                            #389337
                                            Pete Rimmer
                                              @peterimmer30576
                                              It's very unlikely that there's a fault in that motor. You probably need to alter some parameters in the VFD. Do you have a link to the online manual?
                                              #389340
                                                Which VFD have you got? They are far from standard in terms of configuration options and you can't assume that the defaults are correct for your motor (though they might be). The manual may be a hundred pages of cryptic options written for experts – not an easy read. But don't panic, if you can tell us the model, it should be possible to sort something out.
                                                At the moment there are too many unknowns in play – the more information you can provide the better. Model numbers, photos, plate details, what you tried etc. It's a puzzle and the more clues we have the easier it will be to solve.
                                                Daniel Grant
                                                  @danielgrant15006
                                                  Here’s a couple of pictures from the ‘manual’. Not the most thorough document I’m afraid.
                                                  vfd manual
                                                  VFD manual 2
                                                  #389350
                                                  Nick Hulme
                                                    @nickhulme30114
                                                    This is where an inverter from a (Relatively) local supplier who speaks your language helps, better still one which is also from a manufacturer who publishes online manuals in intelligible English!
                                                    #389357
                                                    Alan Gordon 4
                                                      @alangordon4
                                                      Go “ Newton Tesla” you will not be disappointed
                                                      Edited By Alan Gordon 4 on 04/01/2019 17:59:57
