3 phase
3 phase
Home › Forums › Beginners questions › 3 phase
Viewing 25 posts - 1 through 25 (of 30 total)
  • #376624
    michael lennon
      @michaellennon12510
      How do you install 3 phase into a domestic household?
      #9379
      michael lennon
        @michaellennon12510
        #376626
        John Rudd
          @johnrudd16576
          At great expense!
          If you want a proper TPN installation, you will need to speak to your local electrical supply authority.
          The alternative is to use either a rotary convertor or a 230-415 invertor.
          What are you looking at powering?
          #376629
          Clive Foster
            @clivefoster55965
            Cost me £15,000 to have it all laid on, buried cable down to workshop et al. Say 20 yards road to house then 30 yards house to workshop. Maybe 60 all told counting run through house. Then finding an electrician actually able and willing to connect it all up defeated me so 7 years on its still dead.
            4 guys quoted, "yeah we can do it and never came back"!
            At least it cured my RCD and MCB issues. Original feed was damaged and not safe! As I'd know for 40 years and utility ignored.
            Clive.
            #376640
            Harry Wilkes
              @harrywilkes58467
              Posted by Clive Foster on 19/10/2018 13:15:26:
              Clive.
              Clive.
              Where are you located I may know someone who would be willing to finish the job ?
              H
              #376646
              Clive Foster
                @clivefoster55965
                Harry
                Great offer, thanks. I'm in East Sussex.
                Clive.
                #376659
                  Posted by michael lennon on 19/10/2018 12:56:56:
                  Typically in the UK, you don't. It's not impossible but – unless you can show you're going to buy a lot of electricity over several years – the cost is usually prohibitive. It's because the cost of wiring up is usually recovered over several years of big bills, and, because domestic users rarely consume enough power to make that economic, they get walloped with the full up front cost. As a single-phase house might be some distance from a 3-phase source, you might find yourself paying for trenches and poles as well as a the cabling. The second problem is one of safety. You don't want single phase domestic equipment running on different phases in close proximity. Also, most electricians wouldn't touch it.
                  These days there are many inexpensive electronic boxes t hat convert ordinary 240V single-phase into 3-phase specifically to drive 3-phase machines like lathes. VFDs start at about £60 for 2.5HP on ebay. Would one or several of those solve your requirement? Even largish workshops use them rather than plumb in real 3-phase.
                  Harry Wilkes
                    @harrywilkes58467
                    Posted by Clive Foster on 19/10/2018 14:44:54:
                    Harry
                    Clive.
                    Clive PM sent
                    H
                    #376663
                    Anonymous
                      Posted by SillyOldDuffer on 19/10/2018 16:50:56:
                      Typically in the UK, you don't. It's not impossible but…………….
                      Errr, that wasn't my experience.
                      I simply rang the local electricity board and they said they'd send a man out to do a survey. I asked where the nearest 3-phase was, as if it's half a mile away you pay for the whole length so no point getting a quote. But no, they said they'd send a man anyway. Turns out the nearest 3-phase is buried the other side of the road. They quoted £2500 to supply the 3-phase. I understand from a friend in the house building industry that about £1000 of that is for digging up the road. If a utility digs up the road they have to repair the work FOC if needed, for up to a year after the work is done. So given the sub-sub-contractors they employ they whack the price up. No questions were asked about usage or anything else. I just confirmed that the 3-phase meter wouldn't have a wobbly if only one phase was being used. I also checked that I would pay the domestic standing charge and pence per unit.
                      Having 3-phase makes life easy. All the control gear works and I can run two speed motors without any issues, including on the fly switching. The horizontal mill has a 4/5hp Dahlander motor and that's no problem either on proper 3-phase.
                      #376668
                      Mark Rand
                        @markrand96270
                        Did you have to run the pipe/duct from your house to the edge of the property or did they do that bit as well?
                        Edited By Mark Rand on 19/10/2018 18:24:46
                        #376672
                        Colin Heseltine
                          @colinheseltine48622
                          I've put three phase into two properties. The last one was in the late 80's. The three phase supply runs up the road and is 6ft – 7ft below ground level. It runs just inside my property line. I was able to dig a trench across my lawn and under the drive and then tunnel under the garage/house foundations. I dug a 6ft x 6ft x 7ft down to the three phase cable to expose it. I was doing this in mid October, digging by floodlight every night after I got home from work. Had lots of funny comments from people when they realised there was someone down the hole digging. All they saw was heap of soil flying out of a hole.Laid a heavy plastic duct (supplied by the Electricity Board) and then fed the three phase cable through it. Ran it up wall to Meter Location and put up my own Distribution Board. Ran a Single Phase to my house Distribution Board. The Electricity Board turned up, terminated cable at Meter, I put the tails into my Distribution Board and they then cut open the three phase cable and soldered the new cable to the main feeder. All done with it live. IIRC it cost me around £500. The previous one was at my Dad's house for our lathes and milling machines, I did all the same work and it cost even less.
                          A friend of mine has just had the same thing done but he had to have a JCB a the nearest 3-phase was in a field about 100 yards away. Cost him a little more.
                          Colin
                          #376673
                          Gareth Jones 9
                            @garethjones9
                            Hi Michael, my experience was similar to Andrew's. Called the power distribution company who sent over someone to do a survey and prepare a quotation. The nearest 3 phase supply was in the centre of the road outside my house. Power company quoted to dig up the road, connect into the live 3 phase line, and run a 3 phase cable across the road and over to my garage, about 30 to 40 yards. I had to dig the trench (3ft deep) on my property and drill a hole through garage wall. They did it for less than GBP2000. A separate power supplier company then connected a meter (at no cost) and arranged the power contract with me. I then got an industrial 3 phase experienced electrician to wire up a distribution board and some supply lines to two machines. Job done.
                            Gareth
                            #376675
                            martin perman 1
                              @martinperman1
                              Shame I don't need three phase as its six feet from the house and runs along the gardens of all the houses in our Crescent, My builder found it when his digger brought up a busted gas main to my house whilst doing some work for me, don't break a gas pipe it costs £800 to join to ends back together crying
                              Martin P
                              #376677
                              John Haine
                                @johnhaine32865
                                You could buy quite a few vfds for 2000 squids.
                                #376679
                                John Haine
                                  @johnhaine32865
                                  #376684
                                  Gareth Jones 9
                                    @garethjones9
                                    Hi John, I have two motors on the lathe and four on the mill (one of the lathe motors is two speed). At the end of the day I've just connected each machine up and have not had to change any of the installed electrical control systems. Electrical or instrumentation is not my engineering discipline.
                                    My post was intended to provide further information to the original poster to say that having 3 phase installed could be a feasible option.
                                    Gareth
                                    Edited to include 2 speed information
                                    Edited By Gareth Jones 9 on 19/10/2018 20:55:29
                                    #376687
                                    Anonymous
                                      Posted by Mark Rand on 19/10/2018 18:24:25:
                                      The quote stated I would need to dig the trench on my property and install ducting. I couldn't get any sense out of the electricity board about exactly what I needed to do, so I ignored it. The digging team dug down to the cable on the road verge, dug a 4ft long trench my side of the road, another 4ft trench on my drive and a hole by the garage to get to the J pipe. They then moled between the holes and trenches to fit the cable. No ducting was used.
                                      #376724
                                      Alan Vos
                                        @alanvos39612
                                        In the context of computer room equipment, I'm sure I read that the requirement to keep single phase equipment on different phases well apart had been dropped. The chances of a phase-to-phase fault, or touching both phases at the same time, are minimal.
                                        As noted elsewhere, a commercial/industrial electrician should be happy to work on 3-phase. I accept that, by number, most electricians may well be domestic.
                                        For real fun, consider what happens when you lose the neutral on a 3-phase supply powering an unbalanced load of single phase equipment. It is usually expensive.
                                        #376856
                                          Just a comment.
                                          Utilities usually keep the phase loads reasonably balanced by connecting three houses with each one wired in sequence to each of the three phases.
                                          Probably, they would not not be too happy to put in a 3 phase supply and then have one phase more heavily loaded that the others.
                                          #376865
                                          Stuart Smith 5
                                            @stuartsmith5
                                            Contrary to some of the negative posts, you can get a quote for 3 phase by contacting your electricity distribution network operator (DNO). The cost will depend on the location of the nearest suitable 3 phase main cable and the supply capacity you want . If you don't know who your DNO is, you can find out at this website:
                                            Regarding your own internal wiring, a commercial/industrial electrician will be able to quote for the necessary work.
                                            Stuart
                                            #376876
                                            Gareth Jones 9
                                              @garethjones9
                                              Hi Howard, I live in a residential street and when western power connected my three phase supply no mention was made of any concern to balance loads between ajoining residences.
                                              Gareth
                                              #376917
                                              Anonymous
                                                Posted by Howard Lewis on 20/10/2018 21:47:04:
                                                Likewise unbalanced loads weren't raised when I installed 3-phase, except by me to check the meter would cope. Unbalanced loads within one property aren't important. The average over a large number of houses is what matters. I probably cause more imbalance overall using the single phase shower (45A) than anything else.
                                                I suspect that power factor is more of a concern to the utilities.
                                                #376920
                                                Muzzer
                                                  @muzzer
                                                  Yes, it's a complete and total non-issue. A good example of overthinking.
                                                  The house is one on phase already ie the definition of unbalanced. Any additional true, 3-phase loads could only improve the balance. But in the scheme of things, averaged out over thousands of houses, it's of no consequence whatsoever what happens in one installation.
                                                  Murray
                                                  #376937
                                                    Umm,
                                                    Does seem to be quite a bit of confusion with this. At the beginning I said 'It's not impossible but – unless you can show you're going to buy a lot of electricity over several years – the cost is usually prohibitive. It's because the cost of wiring up is usually recovered over several years of big bills, and, because domestic users rarely consume enough power to make that economic, they get walloped with the full up front cost.'
                                                    Andrew and others then describe situations in which connection to a nearby 3-phase source has been achieved for about £2000. (As Colin's £500 was in the 1980's, multiply by 3 to convert to today's money. I wonder if Clive's £15000 is a misprint for £1500?) Anyway, those who paid £2000 all descrive simple cases and I believe they were indeed 'walloped with the full up front cost'.
                                                    We're not all the same in what's considered 'prohibitive' – no way would it be worth my while spending £2000 on on a 3-phase installation!
                                                    But, and this is always the danger of arguing from a small sample, the positive experiences don't cover the situation where making the connection isn't easy. For example, I often drive past an isolated ex toll-house / second-hand car business. It's power comes from a pole-pig that's fed single-phase from overhead wires that disappear on poles across the fields. It's 5 or 6 miles from the nearest town. Likewise, when I lived in the big city, all the wiring was underground. Getting three-phase into my home might have involved digging a trench across a busy main road and private land to a substation about 300 yards away. In difficult cases you could be looking at tens of thousands, perhaps more.
                                                    Most if not all of the people on the forum are electrical small fry. How we use electricity as individuals is unlikely to concern the supplier in terms of power factor or phase balance or finance. Very different conversations are held if the customer is building a new housing estate, a factory, a large office block, an Aluminium smelting plant, or High Speed Two! Part of the fun with installing 3-phase in a home is having to sort out something a bit non-standard on a tight budget. A big outfit might have in-house expertise, or they might pay consultants to manage the project. You're on your own, which is a good way of saving money, but painful if you get it wrong. By all means ask for a quote, don't be surprised if it's serious money, and don't be surprised when your local sparky can't help and leaves you looking for a commercial electrician, who might not be keen to take on a small job. Keep eyes wide open for extra costs – if you physically can't do the on-premises work yourself, or don't understand the regulations, be prepared to pay full market rate for professional help.
                                                    I hope we've done a good job answering Michael's original question. The best case cost is £1500 to £2500 for connection, the internal installation work is extra, and we've identified some likely pitfalls.
                                                    Michael: if you do proceed, please let us know what happens and how much.
                                                    Edited By SillyOldDuffer on 21/10/2018 12:40:39
                                                    #376951
                                                    Anonymous
                                                      I thought long and hard before installing the 3-phase. This was done 15+ years ago when VFDs were more expensive than they are now. One also needs to take into account that my machine tools have large motors, up to 5hp, which makes the VFDs more expensive, and some also require 415V to function properly. I estimated that VFDs were going to cost me a significant proportion of the cost of 3-phase. Another factor was that the existing single phase installation was 60A with a wind yer own fuses consumer unit. The survey before I bought the bungalow pointed this out and recommended it should be changed.
                                                      Even if I could change motors a VFD wouldn't allow me to use the machines properly, particularly those with multi-speed, specialised or multiple motors. And I would also need to fudge the control gear. I suspect some machines would be very difficult to convert, such as the power guillotine. It would probably be possible to fudge the electromagnetic clutch so that it worked, but I'd rather be making parts.
                                                      To summarise, almost all my machine tools are inherently 3-phase and I want to use them, and all their facilities, to the maximum. In addition VFDs were going to be costly and it was sensible to update in the incoming supply anyway. So although it was expensive I don't regret doing it in any way. With the old supply if I was using the hob and oven I might have tripped the system simply by having a shower!
