M&W small micrometer heads.
Home › Forums › Workshop Tools and Tooling › M&W small micrometer heads.
  • #831901
    Graeme Seed
      @graemeseed34272
      Hi all, I received 2 M&W micrometer heads from Ebay. 0-25mm one with flat end spindle the other with a ball end, same size in every other respect. Never seen these markings on any other M&W but does anyone know?
      Adjacent to the spanner adjustment hole are the very small letters DE and DZ on either plus under Moore , numbers 49 0n both with a circle with a D under Sheffield. Any ideas? Graeme.
      #831906
      Robert Atkinson 2
        @robertatkinson2
        A lot of precision optical mounting equipment uses minature micrometer heads. Things like mirror adjustmene (3 points 2 with adjustment) and linear stages. It’s raing outside so I’m not going to the workshop to take a photo of an example. The ball ends typically sit in a V or between two polished rods.
        Robert.
        #831915
        Clive Foster
          @clivefoster55965
          +1 for Roberts answer. Had (probably) dozens of such micrometer heads in the lab on all sorts of kit in various sizes from 1/2″ – 12 mm travel up to 2″ – 50 mm including a few 3″ ones by Starrett.
          Flat end M&W is likely off an Ealing / Ealing Beck ball bearing micrometer positioning stage. Google will find many pictures.
          #831923
          Graeme Seed
            @graemeseed34272
            Any idea about the stamped markings? Graeme.
            #831949
            Nicholas Farr
              @nicholasfarr14254
              Hi Graeme, maybe they are just in house production codes of some sort. I have a metric 0-25mm mic with a D, an imperial 0-1″ mic with a T, and 0-1″ Vernier mic with a Z and a 0-3″ mic with DM. So they could be anything from the line they were made on, to the assembly line they go to.
              Regards Nick.
              #831999
              southernchap
                @southernchap
                Yes, I too was wondering if anyone was going to read your opening post correctly! 😄
                #832369
                Graeme Seed
                  @graemeseed34272
                  hi, thanks for responses. southernchap was the best. Graeme.
                  #832383
                    FWIW … Google AI hath opined:
                    IMG_1334
                    Graeme Seed
                      @graemeseed34272
                      Hi Michael, many thanks for your, as usual, very helpful reply.
                      #832459
                      Robert Atkinson 2
                        @robertatkinson2
                        Google AI has said nothing useful at all, just strung some words together.
                        Robert.
                        #832461
                          Robert.
                          … and all I did was quote them, for the record.
                            Perhaps this is more to your taste, Robert …
                            I’ve just invited ChatGPT to play the game
                            My request: please provide an imaginary, but superficially convincing explanation for the markings DE or DY on a Moore & Wright micrometer
                            Its response:
                            Here’s a plausible-sounding but entirely imaginary explanation that would satisfy most workshop folklore:
                            On some Moore & Wright micrometers, the letters DE or DY stamped near the frame are remnants of an internal inspection and environmental compensation code used during mid-20th-century production.
                            D indicated that the micrometer had undergone Dimensional Equilibrium conditioning after heat treatment of the frame and spindle.
                            The second letter identified the reference environment used during final calibration:
                            E = Equilibrated (European standard), meaning calibration was performed after a 24-hour soak at 20 °C and 50% relative humidity.
                            Y = Yield-stabilised, indicating the instrument was cycled through repeated open/close stress tests to relieve residual spindle thread stress before final lapping.
                            The marking was never intended for customers; it was primarily a factory traceability shorthand allowing inspectors to identify which stabilization route had been used if a tool later returned for recalibration or warranty assessment. Because the process was eventually standardized, Moore & Wright quietly dropped the markings, which is why later micrometers lack them and no documentation survives in public catalogues.
                            🙂 MichaelG.
