Perhaps you need to send us a photo of what your 513 consists of.
Normally they have a motor, a large box of control electronics, with some serious voltages inside and a small box with a movable grey or silver lever poking out, which is the speed controller. All the required connecters are provided and it is a stand alone unit. Plug everything in, turn on, twiddle said lever and it should all work.
If for some reason you do not have the speed controller box and attempt to run, then the control box should fault to a safe condition and no current will be supplied to the motor.
