OOPS.
OOPS.
  • #820604
    Dave S
      @daves59043
      Can you see the problem with the ‘clean up the edges’ part of the tool path?
      IMG_7923
      Yes: failed to notice that the bottom height was set below the vice jaws.
      IMG_7924
      This is what happens to a 6mm Carbide end mill when you try to machine hardened steel at aluminium feed rates:
      IMG_7926
      Didn’t half make a ‘bang’!
      Totally my fault – I was running an adaptive clearing path to rough out the block and the inner section is at Z-4mm – which is Vice jaws +2mm give or take. The outer section of the same tool path headed down to ‘model bottom’. I didn’t notice when checking, or I would have set the bottom height to Z-4mm.
      Sigh, and other ‘learning’ on my CNC journey
      Oldiron
        @oldiron
        Oh dear!  Another learning experience. You hopefully will not make that mistake again.
        #820609
          You get a bigger bang if you plunge straight down into the vice jaws😥
          It is possible to alter the default heights in F360. That way if you forget to change one the worse that could happen is you don’t cut any metal. You can set the default bottom height to model top which is the safest option.
          https://forums.autodesk.com/t5/fusion-support-forum/can-i-change-default-heights/td-p/7969739
          #820613
          Dave S
            @daves59043
            That is a useful thing.
            Going to alter that now.
            Nigel Graham 2
              @nigelgraham2
              Even the professionals sometimes get it wrong.
              One of my former employers proudly bought a CNC mill.
              Then found it a cutter-diameter or so too small for the exterior of a component milled from an alumium-alloy “paving-slab”…
              Solution?
              They re-designed the component so the mill could cope with it.
