A picture of dad at work. …
Excellent photo. The lathe is hard to see, but a bench packed with other goodies. At first glance looks untidy, but I think he’s making best use of the available space. Radio, vice and work-light just so. The picture is dominated front right by his parts cleaner, with 4 different liquids, essential for repair work. Dirt stops clocks!
The wood-turning style is typical of clock making. Suits burnishing as well as cutting, and the latter is done to fit by eye, not by measuring.
When I retired I dithered between clocks and larger work, deciding in the end to go big. Sometimes regret it. Clocks are fascinating and the work is clean and quiet enough to do inside the house. Bigger lathes upset all but the most tolerant house-holder! And then you need a mill, bandsaw, welder, 3 ton press and a gigantic junk box…
Are you tempted to have a go yourself?
