Painting mating surfaces
Home Forums Beginners questions Painting mating surfaces
  • #814195
    Martin Cooper
      @martincooper52042
      Hello everyone
      I’m about 50% through building a 3″ scale traction engine, with all parts as yet unpainted.  Some parts are showing very mild surface rust and so I am starting to think some paint might help.  At this point, I realise I am a painting beginner and need advice please.
      This screenshot shows the front axle, cradled in a spacer which then fits in the fork:
      pic
      The axle+spacer assembly pivots around the pin and so there is some movement between the spacer and the fork.
      Am I correct in thinking that the mating surfaces on fork and spacer should not be painted?  But if the non-mating parts of the fork are painted (ie, the bits you can see in the image) then fitting the spacer into the fork will most likely scrape off some paint from the fork.
      Or perhaps the whole assembly is painted after assembly, with masking tape applied where appropriate.  But then the first time the spacer moves in the fork, it’s going to shear the paint.
      Thank you in advance.
      Martin
      #814201
      Richard Simpson
        @richardsimpson88330
        Running surfaces, be they sliding, rotating or oscillating are best not painted.  Such surfaces frequently work with minimal clearances for smooth running so paint can take up some of that valuable clearance.  The paint can either erode and mix with the oil to form a sludge that can lock up moving parts or it can come off in chunks and again seize up moving parts.  I also do not paint mating surfaces as the thickness of the paint can affect the fit and can make dismantling very difficult.  Mating surfaces are rubbed with steam oil before assembly.
        Generally ferrous parts need painting to prevent them rusting however all running surfaces should be left bare.  It is far easier to paint the parts individually with the running surfaces masked.  I use an acid etching primer followed by coach enamel.  The running surfaces should then be kept oil free by frequent oiling.  It is also possible to blue the metal, which also helps to prevent rusting but it is not as effective as paint or regular oiling.
        This refurbished 10V was painted as individual parts after masking all running faces and mating faces.  The crosshead guide was masked with a paper tube and mating surfaces were masked with masking tape.
        22-11-11-01Stuart10VRestoration30
        A couple of coats of etching primer followed by a coat of two part epoxy paint:
        27-11-11-03Stuart10VRestoration78
        All running gear is left bare with the ferrous parts relying on oil to keep them rust free:
        02-12-11-01Stuart10VRestoration83
        Interestingly the cylinder cover was blued and simply needed cleaning up:
        02-12-11-09Stuart10VRestoration91
        At the end of the day there will always be bare metal components that require attention to prevent rust forming.  I even polish cylinder covers and valve chest covers, which then need oil rubbing into them:
        02-12-11-19Stuart10VRestoration101
        #814202
        Julie Ann
          @julieann
          On my 4″ scale engines, which do not have the blue spacer, the axle and fork are machined to be a rattling good fit, about 40 thou clearance. Both parts are fully painted, two coats of primer, two coats of high build undercoat and two coats of coach enamel.
          On the full size engines I suspect that the axle and fork were not machined to a close fit, just left as fettled castings.
          Julie
          #814206
          Richard Simpson
            Interestingly another area where normal marine practise may vary from normal railway practise.
            #814207
            Dave Halford
              @davehalford22513
              Martin,
              A thin coat of spray zinc rich primer (not the cheap five quid stuff, a good can is quite heavy compared to ordinary spray tins the same size) will stop the rust.
              #814217
              duncan webster 1
                @duncanwebster1
                Richard, photos not showing
                #814218
                Richard Simpson
                  Sorry Duncan but they are showing on my screen.  Can anyone else see them?
                  #814220
                  duncan webster 1
                    @duncanwebster1
                    not showing on PC or phone.
                    #814221
                    Stuart Smith 5
                      @stuartsmith5
                      Not showing on my ipad
                      #814228
                      bernard towers
                        @bernardtowers37738
                        I notice that you use steam oil as a lube but that accepts water wouldnt you be better off using a lube that does not (hyd oil etc)
                        #814229
                        Richard Simpson
                          Maybe its file size, can you see this one?
                          #814230
                          Richard Simpson
                            I guess its open to discussion.  It absorbs water but it still lubricates internal surfaces, so you may be right.  I just use it because I have it handy.  Sometimes I use engine oil if that is lying around.
                            #814231
                              During a progressive long term build as a matter of course you should lightly paint all steel with clear Waxoyle diluted 50% with white spirit. This evaporates to give a slight wax layer that is pleasant to handle and protective. It will need proper cleaning before painting.
                              For rubbing surfaces like the above consider passivating the area with phosphoric acid or a cold black treatment. Both will wear off quickly in use but the very close areas not rubbing will remain protected. Both above, when de-oiled, can be painted without removing, a bit like an etch primer.
                              #814232
                              duncan webster 1
                                @duncanwebster1
                                Yes can see that
                                #814243
                                Richard Simpson
                                  Thanks Duncan, don’t know what went wrong with the initial ones, I can still see them fine.  Maybe something to do with the fact that I use a rather large screen.
                                  I can’t edit the original so I’ll repost the pictures here.
                                  #814290
                                  Pete
                                    @pete41194
                                    If the moving parts or surfaces aren’t ever going to be painted. A few coats of common automotive paste wax (not the liquid type) buffed off so there’s no real dimensional change will keep them from rusting as your build progresses. Afaik, most museums do the same on ferrous and non ferrous metals to slow any rust or tarnishing.
                                    #814294
                                      Don’t use a car wax with Silcone in it or painting becomes difficult.
                                      #814348
                                        Probably not you or your equipment Richard.
                                        1. An intermittent forum bug temporarily delays the appearance of some images. Some members get the pictures immediately whilst others don’t.  The same bug sometimes delays entire posts causing confusion when folk make what appears to them to be a new point, only to discover later that it’s all been said before.  If someone seems not to have read earlier posts, it may be they’ve not seen them yet rather than TLDR
                                        2. The forum linked to a file on your computer rather than taking a copy, so no-one else can access it.  Might be a bug – mostly drag and drop works, not always.
                                        3. Uploads fail due to network or server problems.  The forum occasionally gags whilst resizing large images down to web friendly size.
                                        Martin Cooper
                                          @martincooper52042
                                          Thank you everyone.  Consensus seems to be to not paint these surfaces.  I’ve made the parts to drawing, which means there’s no room for the paint thickness at the moment anyway.
                                          Martin
                                          #814439
                                          Julie Ann
                                            @julieann
                                            Personally I think a front axle looks better fully painted:
                                            Burrell Front Axle
                                            But that’s just me.
                                            Julie
                                            #814473
                                              It will soon sort itself out after a run or two over a rutted rally field with the added oil/grease and ash from the firebox😉
                                              To me the axle is a different type of mating surface to any of the ones on the Stuart 10V which are all static and mostly have gaskets and are surfaces that I would not paint.
                                              The axle is a bit different as the painted or unpainted surfaces become visible as the axle articulates and are something I would be more likely to paint. If you don’t want the paint getting rubbed off then either the casting needs a shallow round “boss” on the inner edges of the fork or you needs to machine the parts narrower to allow a thin washer to be slipped between. As Julie says the axles were unlikely to be machined to within a thou like we can with our miniatures. I would not mind betting they would have been painted after the engine was assembled, just like Julie’s nuts which are painted
