cylinder relief valves
Home Forums General Questions cylinder relief valves
  • #722579
    Garry Coles
      @garrycoles69390
      Hi, A question about cylinder relief valves. Do you set the pressure for these valves at boiler pressure or little bit higher in order to get rid of any water that has built up in the cylinder.
      Garry
      #722584
      Brian Baker 2
        @brianbaker2
        Hi Garry, don’t be tempted to set them too high, I set mine at Boiler Pressure or perhaps just a shade above.  You want them to open as soon as pressure in the cylinder, caused by hydraulic lock gets above safe levels.
        Brian B
        #722595
        noel shelley
          @noelshelley55608
          I’m with Brian, just above the maximum steam pressure, but bear in mind any compression at the end of the stroke depending on timing. Noel.
          #722698
          Garry Coles
            @garrycoles69390
            Thanks for the info, that’s what I thought. Just wanted confirmation.
            Garry
            #722757
            Nigel Graham 2
              @nigelgraham2
              The cushioning pressure of steam is much lower then the admission pressure, because most of what was in the cylinder has expanded and been released before the valve closes to exhaust. It’s condensate that’s the problem, not the compressed steam.
              I would think setting the relief valves to boiler-pressure ideal: the pressure of steam in the cylinder before cut-off is lower than that so won’t open the relief-valves.
              Interesting question, that one. Are many miniature locomotives fitted with relief-valves?
              #722766
              Garry Coles
                @garrycoles69390
                Hi Nigel Graham 2. I thought that I would ask that question because the first loco that I built was Martin Evans  2-6-2 William, which did not have these valves. I did not know about them until I started building Doug Hewsons BR Standard 2-6-4 Tank Loco. So they are a new string to my bow. When I first studied them, I thought about the pressure, and came to the conclussion that the setting pressure must be around the boiler working pressure. I asked the question to make sure that what I thought was right.
                Garry
