ABRAFILES
ABRAFILES
Home › Forums › Workshop Tools and Tooling › ABRAFILES
  • #720455
    metalfettler
      @metalfettler
      ABRAFILES.
      I saw a message (somewhere) very recently referring to breakage of a sole remaining abrafile. ISTR the maker went bust some decades ago. My homebrew filing machine and fretsaw is doomed unless I am mistaken.
      To ward off obsolescence I stocked up on chain-saw sharpening files and coping saw blades but would prefer to have access to the originally determined files/saws.
      For those ” in the dark” Abrafiles were like a metal string clad all round with a cutting dust and incorporated hooks to permit tensioning in a hacksaw – ideal for squaring the corners in panel cutouts. Over enthusiasm with tensioning resulted in snapping but the saws were otherwise quite robust.
      Any thoughts on current availability,   Regards  Les
      #720456
      noel shelley
        @noelshelley55608
        Back in the sixties I used abrafiles, they worked well but were flexible and looked like they were made of some hard aluminium. ones I used were may be about 1/4″ dia and had a handle.  Noel.
        #720459
        bernard towers
          @bernardtowers37738
          Mine are 10 inch for h/saw frame but down to my last half dozen or so
          #720461
            There is [or was] an American product, very similar.
            … Sorry, can’t go looking for details just now.
            Nigel Graham 2
              @nigelgraham2
              The original ‘Abrafiles’ were very thin steel files, and fitted a hacksaw via clips so if you needed cut a profile entirely within the material the pilot-hole for their end beads was of minimal diameter – about 1/8″ I think.
              They have disappeared, but the abrasive wire-saw blades sold in hardware-shops and builders’ merchants for cutting tiles and the like will cut mild-steel. I have not tried them on other metals – aluminium would probably clog them.
              As these are for cutting glazed ceramics they might work on High-Speed Steel, for roughing a blank to shape. I’ve not tried it though.
              They are even more fragile than the Abrafiles were, and their crimped-eyelet ends require a sizeable pilot hole.
              #720481
                  Plenty of threads on here about Abrafiles and sources/alternatives.
                  Can still be had on ebay as NOS
                  #720648
                  Nigel Graham 2
                    @nigelgraham2
                    Does anyone import those Bestway blades?
                    #720830
                    metalfettler
                      @metalfettler
                      Thank you all for your replies concerning availability of Abrafiles. I did a search on ebay but no joy. I may check on the American supplier. First, to find the hooks to render a hacksaw usable. £8 a pair sounds a bit steep. The mention of a wooden handled stand-alone file reminds me after 70 years that this “mousetail” version was my introduction to the beast – used for balsa shaping – aeromodelling on the kitchen table! Was priced at 1s0d; such is inflation.
                      Regards to all,     Les
                      #720834
                        See here, and read between the lines:
                        https://altrish.co.uk/abrafile-replacement-axminster-tools/
                        Credit: Alan Wood
                        george baker 1
                          @georgebaker1
                          Hi
                          I found a brand new (But very old) one in the garage today with fixed wire handles.
                          Somewhere I have a brand new abrafile, new because I only have one end clip. If anyone has a spare to donate please get in touch.
                          George
                          #720880
                          Nigel Graham 2
                            @nigelgraham2
                            Thank you for that link, Michael.
                            That certainly looks a possibility!
                            #720907
                            Nicholas Farr
                              @nicholasfarr14254
                              Hi George Baker 1, the clips are quite easy to make, and although I have a pair of clips, they wouldn’t fit onto the only hacksaw frame I have, that couldn’t be made shorter for some 8″ files that were on e-bay around this time last year. My original clips have a spring retainer to keep the on, but they aren’t essential.
                              001
                              This is the frame I had to shorten with a replacement piece of hollow section.
                              002
                              Regards Nick.
                              #734097
                              george baker 1
                                @georgebaker1
                                Hi
                                thanks Nick, I have just seen your post cos I dont pop in often
                                George
                                #734206
                                Circlip
                                  @circlip
                                  The spring clip retainers were a “Luxury” version for hamfisted Inginhears.
                                  Regards  Ian.
