10ba nuts
10ba nuts
Home › Forums › Beginners questions › 10ba nuts
  • #114025
    nigel jones 5
      @nigeljones5
      Why doesnt someone make some big 10ba nuts?? Theyre far too small and fidley for people like me who have sausage fingers! GRRRRRRRRRRRRR!!
      #6618
      nigel jones 5
        @nigeljones5
        #114029
        Les Jones 1
          @lesjones1
          Hi Fizzy,
          Just buy some 1" hex bar and part slices off it then drill and tap them 10 BA If you also want them 1" long you may have difficulty finding a long enough 10 BA tap !
          Les.
          #114031
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Put a piece of soft rubber tube over a bit of round bar with about 3 mm of tube free . Use to pick up small nuts and to start nuts on male threads .
            MikeW
            #114032
            Mike Clarke
              @mikeclarke87958
              I find a scriber (the ones with a scriber at either end, one at 90 degrees) comes in handy for placing small nuts on threads. Pick one up with the point, hold the tip against the thread, press your finger against the nut as you turn the bolt……or spin the nut with your finger onto a stud.
              For picking things up, you can't beat one of those clawed pickup tools.
              Cheers,
              Mike.
              Edited By Mike Clarke on 08/03/2013 23:14:55
              #114042
              nigel jones 5
                @nigeljones5
                thanks guys
                I cracked it in the end by threading the nut onto a 10ba bolt then transfering it…but prior to this it was impossible!!
                #114051
                Springbok
                  @springbok
                  hi Fizzy
                  I have parkinsons so find work like this very frustrating. but have devised all sorts of tricks including a little bit of blue tack on the end of a rod.
                  Needs must as they say
                  Bob
                  #114059
                  Jim Guthrie
                    @jimguthrie82658
                    I use wooden cocktail sticks if I have problems holding small nuts. I cut the point off until the end will just press into the nut and give enough friction to hold it, then transfer to the end of the screw/bolt.
                    Jim.
