Live steam fittings
Live steam fittings
Home › Forums › Beginners questions › Live steam fittings
  • #109084
    Dismaldunc
      @dismaldunc
      Hi chaps, I'm in the process of finishing my glr vertical boiler and want to use it to power some small stationary engines ( stuart s50 , Tina etc). However the the range of sizes of fittings is making my head hurt….. So I think the question is what size steam pipe do I need to use?
      Thanks in advance
      Dunc
      #6527
      Dismaldunc
        @dismaldunc
        #109157
        nigel jones 5
          @nigeljones5
          use 5/16 x 32 tpi fitting with 3/16 pipe – remember to lag them if you can. Fot the exhaust use 3/8 x 32 tpi with 1/4 tube. This is not set in stone but it will work well and look right.
          #109161
          Dismaldunc
            @dismaldunc
            Thanks mr fizzy , that's all the info I needed. I'm a metric peep so help with the imperial stuff really helps
            #109167
            Bill Dawes
              @billdawes
              Hi Dunc, I know from other other posts that you are a bit ahead of me with your boiler so wondered what test pressure you used or plan to use.
              Bill D.
              #109181
              nigel jones 5
                @nigeljones5
                i too was metric…but if u do this long enough u realise that imperial is much more versitile…in my opinion
