Myford chuck security
Home › Forums › Beginners questions › Myford chuck security
  • #103495
    Trevor Davies 2
      @trevordavies2
      Myford ML7R
      When trying to use rear parting tool and running the motor in reverse I found that the chuck was unscrewing itself off the headstock spindle. When fitting the chuck I lock the spindle by engaging backgear and then with the chuck key tighten the chuck on its thread as much as possible by hand..
      How do I stop this happening so I can use the rear toolpost parting tool?
      #6436
      Trevor Davies 2
        @trevordavies2
        #103496
        blowlamp
          @blowlamp
          Mount the parting tool upside down and rotate in the usual direction.
          #103497
          KWIL
            @kwil
            Please do not engage backgear, you may well end up with a broken gear.
            Does the ML7R have a pin (like the Super7) on the left hand face of the headstock which engages with the step pulley for the purpose of locking the spindle?
            I exhibited a simple device at Sandown MEX which prevents the chuck unscrewing and which may well appear in published form shortly.
            #103500
            Brian Wood
              @brianwood45127
              The ML7R does have a pin as KWIL describes, use that instead of back gear, it is much more positive ion use.
              #103539
              joegib
                @joegib
                You could always fit a chuck lock of the type discussed in this thread when running in reverse:
                Chuck Lock by Woofity
                Similar chuck locks were supplied for their screw-nose lathes by respected companies such as Schaublin so they're not gimcrack devices. This assumes, of course, that your chuck backplate has a spigot 'neck'.
                Incidentally, Woofity's version is a little more elaborate than commercial versions. The latter were commonly a simple split collar with a single screw spanning the gap (the strain relief hole opposite the split is still required, though).
                Joe
                Edited By joegib on 13/11/2012 06:55:12
                #103550
                Nobby
                  @nobby
                  Hi Trevor
                  As blowlamp says mount parting tool upside down
                  Nobby
                  rear parting
