What rpm for a 60mm face mill and slitting saws?
Home › Forums › Beginners questions › What rpm for a 60mm face mill and slitting saws?
  • #73476
    John Coates
      @johncoates48577
      Hi all
      Got myself a 60mm Sandvik Coromant indexable face mill from ebay but am not sure what rpm to run it at in my mill
      Same issue with slitting saws – what speed should I run them at? After almost blunting one after it got very hot I need to know how to avoid this in the future!
      regards John
      #5620
      John Coates
        @johncoates48577
        #73478
        Chris Trice
          @christrice43267
          Depends what material you’re cutting.
          Speeds for HSS tooling at 60mm:
          Steel & Cast Iron 70rpm
          Brass/ Bronze/Free Cutting Steel 160 rpm
          Aluminium 240 rpm.
          Insert tools you can generally run faster.
          Edited By Chris Trice on 16/08/2011 23:50:32
          #73488
          Peter Tucker
            @petertucker86088
            Hi John,
            High speed steel slitting saws can get hot quickly, with the exception of cast iron I would always run them wet. Flood with wetable oil for steel, and a continuous spray of kerosene for aluminium and copper alloys.
            As for speed high speed steel cutting mild steel should have a tooth speed of no more than 100 feet per minute, harder steels and cast iron perhaps half that speed, copper alloys probably a little faster than 100 fpm., and aluminium perhaps 200 fpm.
            If as I suspect your face mill has tungsten carbide cutters, then they will probably “like” to be run a lot faster (perhaps up to 10 times faster ), and you may not notice any difference between running them wet and dry.
            Good luck, and happy milling.
            Peter.
            #73497
            Ian S C
              @iansc
              John, I’v got Arnold Thorp’s book “Vertical Milling in the Home Workshop” . For a 2 1/2″ HSS slitting saw; Mild steel 55rpm
              Brass 95rpm
              light alloy 155rpm
              these speedsare lower than you’ll find in a lot of places, but are suggested for long life of tools. for cast iron , and harder steels you want slower speed, or smaller saw.
                  As far as the face cutter goes I’ll tell you what I was told by an “expert”told me when I bought mine—“Just give it about 2 mm depth of cut, 900rpm, and crank like hell”, well I halve both those figures, and don’t crank quite that fast, it works OK for me, actually I think the usual speed I use is 520 rpm.   Ian S C
              Edited By Ian S C on 17/08/2011 14:25:19
