Why is it so hard to find materials in the UK?
Home Forums Beginners questions Why is it so hard to find materials in the UK?
  • #73294
    Martin Brundell
      @martinbrundell
      I have been looking to buy some grade 2 Titanium tube at 38mm (1 1/2) and 31.75mm (1 1/2) with a wall thickness of 3mm (approx) and boy what a job it’s turned out to be. No one (apart from a firm who want £140 a metre for grade 9) seems to have any in the UK. A friend got some 31.75mm ti earlier this year for approx £35 a metre which was a good price.
      So then I started looking at high grade aluminium e.g the same OD with a slightly higher wall thickness in 7075-T6 aluminium and I hit the same wall…
      Now of you go to China, USA, Germany, Russia and any number of smaller Countries you can get it – but not the UK.
      Does anyone know of a decent supplier for either of these? I initially need a few metres for stress/pressure testing then a bigger order.
      thanks
      #5615
      Martin Brundell
        @martinbrundell
        #73300
        John Stevenson 1
          @johnstevenson1
          Try Ti-Tek at Birmingham, they will sell you exactly what you want to the inch – provided they can get it.
          John S.
          #73306
          Rob keeves
            @robkeeves73950
            Try
            Aviation Metals Ltd
            Michigan Drive
            Milton Keynes
            Buckinghamshire MK15 8J 01908 210012
            Always willing to help me.
            #73311
            David Southwell ARPS
              @davidsouthwellarps
              I lived & worked in California for a number of years. There most stockists in Ca have an offcuts display adjacent to their sales counter and do not have a minimum purchase order when you are collecting. The offcuts section generates good custom.This makes it easy to pick up small quantities of practically any material you need.
              UK stockists are very reluctant to do this for some reason I cannot understand. It seems to be something to do with a prevailing culture in the trade.
              David
              #73315
                They are not all reluctant to sell bar ends, plenty to choose from here
                J
                #73316
                John Stevenson 1
                  @johnstevenson1
                  Every one of my suppliers sell bar ends ?
                  Rang ASC Metals up at Lincoln on Friday for two bars of 2″ x 3/4″ 6061 for a job and I need a bit of 6″ x 1/2″ but nowhere near a full length of 4 metres.
                  They checked the computer and had a piece 1.2 metres which will be fine for what I want, being delivered, Monday am.
                  Forgot to mention in the previous post Ti-Tek only do titanium, I make pump shaft for Ferric Chloride tanks and Titanium is the only metal it won’t eat. I buy 30mm diameter by 350mm long one piece at a time as needed because of cost, again sent thru the post next day.
                  Can’t speak highly enough of them.
                  John S.
                  Edited By John Stevenson on 13/08/2011 13:44:16
                  #73319
                  Windy
                    @windy30762
                    I have found West Yorkshire Steels Wetherby very helpful.
                    Windy
                    #73320
                    Clive Hartland
                      @clivehartland94829
                      For some time the foriegn products have been a bit suspect.
                      My son works for an Underwater Gas and Oil exploration company and sources materiel and finished items from many sources.
                      Some stainless steel pipe and elbows were fitted into the high pressure air system in an engine room and subsequently and elbow exploded, luckily no one was injured as my son had just left the engine room!
                      The investigation returned the fact that the source of the elbows was from an unknown source and they were all suspect even though a certificate of conformation had been issued!
                      Another example was a Stainless steel ‘U’ shackle rated at 7 tonne which sheared showing crystalline fracture. Again from an unknown source with again a certificate of conformation on it.
                      This has made my son very careful where the suppliers get their goods from.
                      It was surmised they were from Chinese sources but they could not verify where they came from.
                      take care with imported materiel.
                      This brings to mind the tade in fake aircraft spares, all found to be lacking and dangereous.
                      #73334
                      Steve Garnett
                        @stevegarnett62550
                        Because we’re rapidly becoming a manufacturing also-ran. Our local metal supplier here is doing nothing like the business he was three years ago. People are now often having to turn to suppliers that aren’t exactly local to them any more, and for the country as a whole, this doesn’t bode too well, I’d say. And when you look at the price hike there’s been on a lot of raw material (especially anything containing copper), it’s not too difficult to see why a lot of small firms are simply giving up – they can’t compete at all.
                        I think that’s enough doom and gloom for one day!
                        #73339
                        michael howarth 1
                          @michaelhowarth1
                          I am no businessman but speaking as a customer, it seems to me that It used to be that retailers, in particular hardware shops and the like, would keep comprehensive stocks of materials for years, not only to hopefully make a profit but to provide a full service to their customers (who would no doubt return if they received good service). Such businesses are now as rare as hens’ teeth, having been absorbed into or wiped out by large national and international outfits who, whatever their PR might say, have as their priority the creation of profit. Customer service/satisfaction is of secondary consideration if of any consideration at all. In my last two visits to B&Q, the oft quoted refrain, “If it’s not on the shelf, we haven’t got it”, applied. What did I require? Turpentine (the real stuff) and a 40mm plastic waste elbow.
                          Does anyone remember Edwin Penny’s hardware store in Enfield?
                          #73344
                          Clive Hartland
                            @clivehartland94829
                            Thats why every engineer keeps a scrap bin on the off chance he will need a specific piece of metal.
                            I think its being called being a ‘Magpie’, sheds full of useful junk!
                            #73350
                            NJH
                              @njh
                              Spot on Clive. Of course it doesn’t end with the scrap bin does it? How about all those useful lengths of timber, used but good condition nuts, bolts, screws etc . Pots of paint where only 1/3 has been used, lengths of rope, bits of cable, containers ejected from the kitchen but seen as of possible use in the workshop……………..I could go on and on. I am very in tune with this as I am at present in the midst of a clear up but one thing is absolutely certain. When I have decided on all the things I don’t need and taken them to the tip I can guarantee that within a few days I will find a use for most of it! ( even though it had been “lost” for years)
                              Norman ( Magpie)
                              Edited By NJH on 14/08/2011 11:16:56
                              #73352
                              Donald Lunn
                                @donaldlunn12212
                                I have a small but dwindling stock of various metal,it is very difficult to obtain odds and ends to keep up the stock.One time you could walk into a scrapyard and pick over what they had,but now they don’t even want you in there,unless you are selling them, some scrap.So probably from now on, when i decide on a specific project, i will just bite the bullet and buy the metal to build it.Who knows i might even get some offcuts from it !!
                                Don (Another Magpie)
                                #73353
                                michael howarth 1
                                  @michaelhowarth1
                                  The trouble is I’ve got two shedsfull of useful junk in my shed.
                                  #73371
                                  Jon
                                    @jon
                                    Agree Ti-Tek probably best for TI in Midlands.
                                    Also have an account with ASC but can go in and have a look around for stainless’s and alums, the wall by the saws usually stacked high with off cuts.
                                    Bay prices seem horrendous especially when adding postage on. Reckon on there gone about 60% the last 6 months. Used to buy short 1 and 2M lengths off there, now i will always go to ASC 5 mile away and buy full lengths have them middled so can get in car, free.
                                    If you have too much junk you can never find what you want, draw the line some where.
                                    Wish i could salvage the swarf but takes up way too much rooom even after three days.
                                    #73372
                                    Martin Brundell
                                      @martinbrundell
                                      Thanks for all the suggestions – I will get onto them tomorrow.
                                      #73379
                                      Jon
                                        @jon
                                        Better to pop in Martin ring the bell.
                                        Northampton
                                        Peterborough
                                        Wolvo
                                        Lowestoft
                                        Just had a look at a certain size of aluminium by a co advertising on here, shocked almost 4 times cheaper at ASC.
                                        I would also be interested in other companies selling aluminium 6082T6 at a reasonable price. Looking for 5 1/4″ round 14 to 16mm thick x 60 off dreading the price this year knowing its all gone up.
                                        #73407
                                        AES
                                          @aes
                                          Re material suppliers:
                                          I have had excellent service from Noggin End Metals of Stoke on Trent. The prices are very competitive for small quantities & off cuts, etc. He is only open for personal visits by appointment but often trades at various shows and has a very efficient mail order service.
                                          Usual disclaimers.
                                          Web site (with catalogue and contact) at:
                                          Quote from the homepage:
                                          QUOTE:
                                          Aluminium, Brass, Bronze, Cast Iron, Copper, Silver Steel, Stainless Steel, Engineering Plastic. Exotic Materials including:
                                          EN24T High Tensile Steel, 2014 (HE15) High Tensile Aluminium (Dural), Titanium, Colsibro and Colphos.
                                          UNQUOTE:
                                          He’s always been open to finding “special” stuff every time I’ve asked too.
                                          Hope this helps
                                          Krgds
                                          AES
                                          Edited By AES on 15/08/2011 09:03:02
                                          #73414
                                          John Stevenson 1
                                            @johnstevenson1
                                            Posted by Jon on 14/08/2011 15:17:04:
                                            Well just got my 3/4″ x 2″ delivered £42 for a 4m length plus £7.50 delivery plus the dreaded VAT so £59.40
                                            The same company who advertise here wants £58.51 for ONE metre, so as Jon says 4 times dearer.
                                            John S.
                                            #73421
                                            Jon
                                              @jon
                                              Postage on that is quite cheap John, personally i wouldnt mind if it took 4 days for that.
                                              May have got it for £30 if gone in but lost downtime like myself.
                                              1 1/4″ round 6082T6 used to be £32 for 4M length direct last year and for years, interesting how much it will have gone up.
                                              The cut to size is pretty good as well on price. Usually have round cut 14 to 16mm thick 5 1/4″ x 16 £5.29 ea for 30 off as at November, 4 1/2″ x 18mm thick £3.60 ea for 30 off said double it. Had 30 off 5″ as well sub £4 ea.
                                              Largely dependant upon the sales person, i have paid a lot more from same place for years.
                                              One such national company with an A in the name i used to buy alum by the tonne wanted £10 ea for 4″ dia x 13mm thick back in 93.
                                              Any other cheap suppliers let us know.
                                              #73423
                                              John Stevenson 1
                                                @johnstevenson1
                                                Posted by Jon on 15/08/2011 13:53:29:
                                                That’s not postage, that was truck delivery, they deliver everyday to this area, Notts / Derby / Leicester.
                                                It’s £7.50 regardless if i want one tiny cut of piece or 20 lengths.
                                                I dare say other trucks do different areas.
                                                If I get an order in for about 3:30pm, I’ll get it next day. The order delivered today was phoned in Friday Afternoon
                                                John S.
