Muncaster 2 Cylinder Engine
Home › Forums › Miscellaneous models › Muncaster 2 Cylinder Engine
Viewing 25 posts - 1 through 25 (of 47 total)
  • #618320
    Paul Lousick
      @paullousick59116
      The linkage arms on the Muncaster engine below are supposed to keep the piston rod aligned with the axis of the cylinder but the left arm (one with a middle pivot point) has a slotted hole instead of a round hole, allowing the arm on the right to float in the slot.
      This does not keep the piston rod aligned exactly with the cylinder axis because of the slop. Is this normal with this type of guide-linkage ?
      Does anyone have geometric design data of how these linkages are supposed to work?
      #4362
      Paul Lousick
        @paullousick59116
        #618325
          I'll have a look could it be another of Julius' features?
          #618327
          pgk pgk
            @pgkpgk17461
            The bottom left-hand pic shows duplicate control arms to the one piston rod, presumably the other pic is simplified for clarity.
            The right-hand pic showing the slot does make some sense, since the rod attached to the pillar has to describe an arc otherwise.
            pgk
            #618328
            Paul Lousick
              @paullousick59116
              (Yes, the front arms in the detail views have been removed to see the slot in the rear arms)
              I understand that each pivot arm describes an arc and assumed (should never do that) that both arms working together would cancel out the problem. If the slot is required, the rod will not be guided properly and will wobble as it moves. Not an ideal design but they look good when they move.
              #618465
                like you say the slot would allow some sideways movement, I have not been able to find where I thought I had details of the linkages but a couple of other examples, not the square tops to entablatures that I mentioned in your earlier thread on both examples.
                Here and here
                #618478
                Paul Lousick
                  @paullousick59116
                  Thanks Jason
                  #618488
                    If it is anything like most versions of Watt's Parallel Motion Linkage on beam engines, it does not guide the rod end in a truly straight line, but in a very shallow S curve. Which worked ok on large engines for Mr Watt & co when they had very loose fitting pistons with leather piston rings and thick but loose packing around the gland. It allowed for a little bit of movement and misalignment.
                    So the slot may be to allow a more rigidly/tightly made modern model to function without the linkage binding, as the piston rod is held steadily vertical by the tight fitting piston and gland. So it has the "look" but is not really doing the guiding. Good enough for small model purposes.
                    If you Google Watts Linkage or Parallel Motion Linkage there is a lot of info. Wikipedia does a good summary, describing the path of the piston rod end as a shallow figure 8 rather than straight line. LINK
                    Edited By Hopper on 25/10/2022 06:47:45
                    #618489
                    pgk pgk
                      @pgkpgk17461
                      I took a look at the drawings. That slot is given as 6x5mm with the linkage from it to the piston rod being quite short. It'd be interesting to sketch out parts of the arcs of movement from the flywheel at top & bottom because it looks like the 'wobble' will be quite small with the short length of linkage from there to the piston rod.
                      I also note that that bearing insert is given as brass – perhaps worth swapping to bronze??
                      #618496
                        I am not familiar with the drawings under discussion, but I did have a Watt's linkage [on the rear of the Scimitar] which prompted me, years ago, to find this:
                        **LINK** https://www.gutenberg.org/ebooks/25155
                        HOW TO DRAW A STRAIGHT LINE
                        A LECTURE ON LINKAGES
                        Essential reading, I would suggest, for anyone interested in more than just making the holes bigger.
                        Edited By Michael Gilligan on 25/10/2022 08:06:32
                        #618498
                          Some good stuff there but could not obviously spot one like the engine and all are pivots not slots.
                          I'm 99.9% sure Julius took his from Westbury's artcles about Muncaters designs. What would be useful is if anyone has issue 1756 from Vol 72 that described these engines
                          #618499
                            Posted by JasonB on 25/10/2022 08:06:25:
                            l
                            Sorry, Jason … it was just a broad recommendation, not intended to be specific to this model.
                            The use of pivots, without things locking-up, is a good demonstration of ‘geometric purity’
                              I just put a scan of the Illustration from Westbury's article into Alibre, scaled it to suit Julius' 73mm long link with the slot and then measured the other links.
                              The ctr of the slot on Julius' one is 26.5, mine 26.235.
                              The one on the left 90 for jules and 89.5 on mine
                              But the one anchored on the right has more of a difference as Jules has it at 63mm and it scales out almost 675mm on mine.
                              Needs the individual links drawing and simulating but small differences like this could make the difference between a round hole and a slot. If the geometric relationship could be found that may make things easier.
                              Link to Julius' drawings
                              Link To Westbury's article
                              #618501
                                But a General Assembly drawing is not necessarily drawn accurately to perfect scale.
                                #618503
                                  I have just learned something ‘new to me’
                                  [quote] unique for that time, these were designed as models, not scaled down industrial items. As such they were designed in their own scale [/quote]
                                  … and, I regret, that ^^^ probably says a lot.
                                  Ref. __ **LINK**
                                  https://modelengineeringwebsite.com/Henry_Muncaster.html
                                  Edited By Michael Gilligan on 25/10/2022 09:08:05
                                  #618504
                                    Thanks for the Westbury link, Jason
                                    I have just downloaded the document to read tonight.
                                      Posted by Hopper on 25/10/2022 08:53:10:
                                      Indeed but it is what Julius used so reasonable to expect that he should get proportions the same as I got which he has in 3 of the 4 dimensions
                                      Don't know if you saw the recent grasshopper thread Hopper but Julius is not averse to putting a 6mm pin in a 7mm hole to get things to move!
                                      #618521
                                        Posted by JasonB on 25/10/2022 11:28:27:
                                        Ah ok. I was thinking he had worked off of more detailed drawings.
                                        Yes I remember seeing mention of the pin and hole issue. Julius does seem to churn out an awful lot of these drawings, all of them incredibly detailed. I suppose he can't get all of it right all of the time. And I don't suppose he would build a working model of each project to "prove" his drawings.
                                        Surely in this age of CAD, a virtual model of the parallel motion linkage could be drawn up at various positions and the track of the piston rod eye (or that slotted hole) determined, to see if it would be straight or the more usual shallow S or figure 8? In the bad old days we would have drawn it out in enlarged scale to do the same, or even made cardboard templates pinned to the drawing board and then mapped out with a pencil the track of the piston rod end as the cardboard model went through its full range of motion.
                                        #618525
                                          I'm not even sure if Muncaster's original had much more in the way of dimensions as it was only in a single issue and not noted as having a pull out plan like some of his but hopefully there was some text.
                                          #618527
                                          Paul Lousick
                                            @paullousick59116
                                            Thank you gentlemen for the reference data. You have given me something to play with and do as suggested and plot the linkage motion.
                                            Paul
                                            #618531
                                              I suppose you could go straight to the source and ask Julius. His contact details are on the bottom of many of his drawings, including his business name and email address etc.
                                              Edited By Hopper on 25/10/2022 12:52:27
                                              #618535
                                                I've done a plot using those sizes I got off the scan, it's close but does drift off to one side, changing the right link for Jules' length makes it a lot worse but he may have tweaked the mounting points.
                                                Also tried substituting some nominal imperial sizes based on the horizontal link being 3" but get various deviation from the piston tod axis.
                                                #618545
                                                  Some more fiddling ha sgot me the required stroke if I allow a +/- limit of 0.15mm on the piston rod in it's hole so I'm sure it could be made better with some more playing about.
                                                  However I have just found this which looks promising, I think Michael may enjoy a look. part of this source of interesting stuff
                                                  #618560
                                                    Thanks, Jason, for the links to linkages yes
                                                    I’ve only just arrived home, so that’s my evening entertainment sorted.
                                                      Another useful reference: **LINK**
                                                      https://www.gutenberg.org/files/27106/27106-h/27106-h.htm
                                                      Consider Figure 14 in the second section
                                                      [sorry, I haven’t found the William Freemantle patent]
                                                      Now … Here is the Scott Russell mechanism, 21st Century version: **LINK**
                                                      https://jaset.pressbooks.com/chapter/design-and-analysis-of-a-modified-scott-russell-straight-line-mechanism-for-a-robot-end-effector/
                                                      Edit. __ Appendix E of this PhD thesis is also worth a look:
                                                      https://core.ac.uk/download/pdf/186333083.pdf
                                                      Edited By Michael Gilligan on 25/10/2022 21:45:43
                                                      Edited By Michael Gilligan on 25/10/2022 21:47:31
                                                    Home › Forums › Miscellaneous models › Topics
