Hit & Miss Engine – Help Needed
Home Forums Stationary engines Hit & Miss Engine – Help Needed
Viewing 25 posts - 1 through 25 (of 34 total)
  • #653586
    Blue Heeler
      @blueheeler
      G'day all, I have taken more than a few days to build the base for this 6cc Hit & Miss Engine. Really happy how it turned out. I can't get a spark from the plug. Has anyone got any thoughts on what to check out to see why I'm not getting a spark? I've pointed out in the video a few things where I'm stuck.
      #3554
      Blue Heeler
        @blueheeler
        #653589
          Check where the wires are soldered to the switch could well be shorting there either to other parts of engine or to themselves
          Their ignition moduels are built for Hall sensors that have 3 wires but the contact type switch only required two of those
          Edited By JasonB on 25/07/2023 07:17:25
          #653590
          Blue Heeler
            @blueheeler
            I will do that Jason thanks, I just had a look and they aren't touching but they are really really close.
            Appreciate the comment(s) its frustrating when something just can't get even a spark of life to it.
            #653592
              Just saw the governor query, The arm will move once the weights start to get thrown out and engage with the latch on the pushrod which holds the exhaust valve open so it will "miss"
              Also worth putting your tester between spark plug body and the wire loop of the earth (not the screw) to make sure you have a clean contact, might want a bit of paint scraping off the head.
              How Gov should work
              #653595
              Blue Heeler
                @blueheeler
                Thanks for the link to the vid Jason, appreciated mate.
                You maybe onto something else that I need to check out. I took out one of the head bolts and slipped the earth in the bolt and put it back, But I have only been putting the probe on the head of the bolt and not the wire loop.
                #653628
                Nigel McBurney 1
                  @nigelmcburney1
                  When I restore full size engines I always ensure that there a good earth path through the engine parts and castings,I remove any paint from mating surfaces and put spikey shakeproof washers on at least one of the securing bolts/studs to get good contact,, you have an earth attached to the cylinder head,so it could just be paint on the head casting where the earth terminal sits,so clean away any paint and place a shake proof washer between the head casting and the terminal on the earthlead. I would have thought that flicking the contacts with a piece plastic would have produced a spark. Though not applicable to your engine I have come across magneto (low and high tension) ignition engines where some restorers have cleaned off the paint from the magneto seating surface and bracet but had forgotten to clean paint off the mating face on the bracket and the engine crank bed. I would follow Jasons advice with the electrical connections as I have no experience with Hall effect devices.
                  #653632
                    You may well not see a spark at the contacts as the current is so low, that is why the don't have tungsten disks to resist the errosion of a spark
                    #653654
                    Engine Builder
                      @enginebuilder
                      Faulty ignition module?. I had one of these fail after a few runs.
                      #653655
                      Engine Builder
                        @enginebuilder
                        #653722
                        Blue Heeler
                          @blueheeler
                          Appreciate all the replies, thank you all.
                          For someone like me with limited electronics knowledge is there a way to test using a multimeter if the ignition module is faulty?
                          Can I put a probe on the spark lead and get a reading?
                          #653730
                            Easier to put the HT and earth very close together and then make the contacts see here
                            #653853
                              Just hold the lead in one hand and spin the engine. You should be able to tell if there is some output. Better not to hold the engine with the other hand if you have a pacemaker?
                              #653855
                                Posted by not done it yet on 26/07/2023 19:54:57:
                                That is also a sure way to blow the CDI, they should not be run without a chance of the spark being able to jump from HT to earth
                                #653884
                                Blue Heeler
                                  @blueheeler
                                  Posted by JasonB on 26/07/2023 06:49:20:
                                  Jason……appreciate that link mate…thank you.
                                  #653893
                                  Blue Heeler
                                    @blueheeler
                                    Hit & Miss Engine Help Needed – Part 2
                                    Really appreciate all the help and advice that I have had from – Thank You. I've put this second help video up as I'm still stuck getting a spark and the wiring has me really baffled. I've tried to point out in the video what is confusing me, so I hope I have explained it well enough to be able to obtain some help and advice…..as always super appreciated guys.
                                    Edited By JasonB on 27/07/2023 07:12:07 Moved to the original thread to save people looking for the first.
                                    Edited By JasonB on 27/07/2023 07:12:58
                                    #653894
                                    David George 1
                                      @davidgeorge1
                                      Hi the wireing for a proximity switch is usually brown positive blue negative and black signal. To get an output you need to use the power and signal wires not the negative wire on a microswitch. Have you a wireing diagram for the coil item or some details of model and maker to search with. Try red and white wires on the microswitch
                                      David
                                      Edited By David George 1 on 27/07/2023 06:26:38
                                      Edited By JasonB on 27/07/2023 07:11:56
                                      #653899
                                        With apologies if you have already done so … could you please post a clear photo of the text on that yellow box-of-tricks.
                                        … or a link to the supplier
                                        Edited By JasonB on 27/07/2023 07:11:41
                                        #653903
                                          It's the magic in the box.
                                          The black wires be they to the battery, contacts or looped wire to the engine are all ground/earth so you will get continuity.
                                          Unlike traditional points the contacts are not part of the power circuit or the HT circuit they all go back to different parts of the circuit board.
                                          Probably not a good idea to have put +ve power to the red wire with the tester.
                                          I've said it enough times on the three forums all the CDIs I have seen on the market work with either Hall sensor where the middle wire is signal or with some form of contacts where just the outside two wires are used, colour varies between makers. I'll take photos of mine to show the two outer wires of the three being used a bit later
                                          #653911
                                            Here is one of my S/S ignitions. You can see that the red signal wire from the CDI stops at the futaba socket and I just have the two outer black & white wires from there that I connect to the contacts on the engine. Same Futaba socket will accept a Hall sensor with it's three wires.
                                            #653913
                                            Trevor Johnson 1
                                              @trevorjohnson1
                                              CDI systems work completely differently to the conventional points/condensor systems. Different wiring connections and colour schemes are used by different manufacturers, suggest as it is a new model/machine   you contact the supplier/manufacturer for further help /advice.
                                              Always watch your interesting channel and hope you can get this issue resolved.
                                              Edited By Trevor Johnson 1 on 27/07/2023 08:49:51
                                              #654046
                                              Blue Heeler
                                                @blueheeler
                                                Posted by Michael Gilligan on 27/07/2023 07:06:57:
                                                Hi Michael, just took these two photos –
                                                https://www.flickr.com/photos/198834535@N04/53075970501/in/dateposted-public/
                                                https://www.flickr.com/photos/198834535@N04/53076472928/in/dateposted-public/
                                                Edited By Blue Heeler on 28/07/2023 00:39:50
                                                #654048
                                                Blue Heeler
                                                  @blueheeler
                                                  Posted by JasonB on 27/07/2023 08:45:57:
                                                  Thanks Jason for taking that photos and also the many replies, truly appreciated.
                                                  #654049
                                                  Blue Heeler
                                                    @blueheeler
                                                    Posted by Trevor Johnson 1 on 27/07/2023 08:49:07:
                                                    Thanks Trevor, very much appreciated
                                                    Jim
                                                    #654050
                                                    Blue Heeler
                                                      @blueheeler
                                                      Thanks one and all for the replies. Sorry for the tardy replies, just in case you don't know I'm in Australia so the time zones play havoc.
                                                    Home Forums Stationary engines Topics
