Stainless steel
Stainless steel
Home › Forums › Materials › Stainless steel
  • #492692
    colin hawes
      @colinhawes85982
      Worn out windscreen wiper rubbers contain two inserted springy stainless steel strips ~ 2.5 x 0.8mm x blade length and easily removed .More free metal for the model making supply!
      #30057
      colin hawes
        @colinhawes85982
        #492695
        Bo’sun
          @bosun58570
          Hi Colin,
          A man after my own heart. I salvage nuts, screws and washers from most things destined for the scrap bin. Sad isn't it? However, any other suggestions for free stuff are gladly welcomed.
          #492706
          J Hancock
            @jhancock95746
            Disposable lighters for miniature O rings /springs /ball.
            Printers , where new printers are cheaper than ink replacement !
            #492708
            David George 1
              @davidgeorge1
              The little wheel from lighters make small knurling tools.
              David
              #492774
              Jouke van der Veen
                @joukevanderveen72935
                Hi Collin,
                I also keep some steel strips from windscreen wipers available. Just this afternoon I found such a strip that had fallen down from the top of the tool cupboard on my workbench. Until now no application for these strips.
                Jouke
                #492988
                larry phelan 1
                  @larryphelan1
                  Something wrong when it,s cheaper to replace the printer than the ink !!
                  Must be one Hell of a rip-off somewhere along the line.frown
                  #492990
                  Steviegtr
                    @steviegtr
                    Posted by larry phelan 1 on 27/08/2020 16:48:13:
                    Yes it's like when you buy a new printer it comes with ink cartridges with just a bit of ink in them.
                    I only use HP printers now , as the cartridges for some are stupendous.
                    Steve.
                    #492991
                    jimmy b
                      @jimmyb
                      I think the "nearly empty cartridge" is just an urban myth.
                      The money is made out of the repeat buying of ink, much like a lot of consumer products.
                      Jim
                      #492993
                        They're doing it on purpose. Cars, computers and electronics get better year on year, but domestic printers get worse and worse. Unreliable expensive ink gobblers because the profit is in the consumables and regular replacement. Chipped half empty ink cartridges that can't be refilled; ink wasted by constant 'cleaning', paper jams, and pipes and nozzles that gum up. Office printers are much better and ink is cheap, but they're expensive to buy, not worth it unless you do lots of printing.
                        I've switched to a black and white laser printer for letters etc and have photos done on the internet.
                        sad
                        KWIL
                          @kwil
                          At least on Canon printers you can reset the chips.
                          #492998
                          Stuart Bridger
                            @stuartbridger82290
                            After getting completely fed-up with endlessly buying HP ink cartridges at no small cost, I moved to an Epson Ecotank based printer. Still using the original bottles of ink a year later with plenty still available
                            #492999
                            Brian H
                              @brianh50089
                              I did a cost analysis (very roughly) and concluded that HP Instant Ink was the way to go. The printer tells HP when ink is getting low and sends a new cartridge and a bag for sending the old cartridge back to France (postage paid).
                              The cost for 50 pages a month is less than buying cartridges for my other printer, but I keep it because it does A3 printing.
                              Brian
                              #493007
                              S.D.L.
                                @s-d-l
                                Posted by Stuart Bridger on 27/08/2020 17:39:03:
                                +1 Done the same been using it 2 or 3 years of fairly heavy B&W use and only on second bottle of ink.
                                Steve
                                #493008
                                Tim Stevens
                                  @timstevens64731
                                  The pump-type hand wash bottles seem (when rinsed properly) to be ideal for oil in the workshop. And within the pump is a stainless spring – very handy.
                                  Cheers, Tim
                                  #493032
                                  mark costello 1
                                    @markcostello1
                                    The almost empty ink cartridge included with a new printer is no urban myth here, buying commercially refilled cartridges is also worthless as 2 of them have been empty, 2 out of 2 for a loss. One store made it right, another did not. Switching to a laser printer when these cartridges are spent.
                                    #493107
                                    Anthony Knights
                                      @anthonyknights16741
                                      +1 for the Ecotank. I've had one for about 18 months and still using original ink bottles.
                                      #493110
                                      Nick Clarke 3
                                        @nickclarke3
                                        A new inkjet printer with separate ink tanks and head will need to fill the head from empty but will indicate that the cartridge needs replacing when the cartridge is itself empty. The replacement cartridge will not need to do this so appears to print more pages that the original ones supplied.
                                        Regarding colour laser printers sometimes a part filled set of cartridges has been supplied with the machine amongst the 6 I look after, but I really can't give a reason why as surely to produce the lower capacity cartridges in smaller quantities must cost the manufacturer more per item.
                                        The other piece of advice learnt the hard way is to use an inkjet printer. If left standing heads clog up and replacing them is not economic. The printer is junk. If it is a printer where the head is part of the cartridge you do not have this problem, but the cartridges are then very expensive – a genuine HP colour cartridge with integral head for one of my printers is now £70 and the black £50. And remember if buying genuine HP it may still be recycled – hence the HP Instant ink system.
                                        #493112
                                        Nick Clarke 3
                                          @nickclarke3
                                          Posted by mark costello 1 on 27/08/2020 20:13:13:
                                          While colour laser technology is good remember that it is not photo quality and photo paper is not compatible with a colour laser printer. If you wish to print photos (the only job I still use an inkjet for) ink jet is the only domestic solution available.
                                          #493122
                                          Nick Wheeler
                                            @nickwheeler
                                            Posted by SillyOldDuffer on 27/08/2020 17:17:53:
                                            A business model that goes back to 1903, and the Gillette safety razor……
                                            #493127
                                            Ian Welford
                                              @ianwelford58739
                                              If you ask nicely the bottles containing hair colouring with nozzles make excellent dispensing bottles for oil, water , coolant etc Smell at bit odd at first but after a couple of rinses…
                                            Home › Forums › Materials › Topics
